Old 02-19-2010, 01:12 PM   #1
hatchbackkid82
Drives: .
Thanks man
Originally Posted by marlondog View Post
It's when the wheels stick out enough to be flushed with the sides of the car. The car is also dropped, and the wheels are tucked in at an angle to keep the tires from rubbing. Requires fender rolling,new fenders later on,negative camber,stretched tires,time and money.
Old 02-19-2010, 02:10 PM   #2
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Originally Posted by hatchbackkid82 View Post
Thanks man
No prob! Still trying to figure the whole thing out myself.
marlondog is offline   Reply With Quote
Old 02-21-2010, 08:04 PM   #3
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
Flush means having the rim lip flush with the fender, this can be done by stretching a small tire on a very wide rim with a very crazy offset not meant for your car. It also requires a quite a bit of poke, rolled and pulled fenders, wheel adapters and or spacers. It can also require grinding down the calipers to so the rims clear that depends on your back spacing. You also need either custom shims or camber bolts or companys make them. Extended wheel studs come in handy as well. You can achieve the look in many ways, custom shortend struts with cut springs, coilovers, air ride... The list goes on. If your not rubbing and rolling rough your not low enough! It can cause some major problems if not done right! I've already messed a fender up and went back to lowering springs until garm hooks me up with some new goodies!
Help Me Get That Slammed Look... 9vapors Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 02-27-2011 10:27 AM
Daytime Pics of the Slammed 09 5door counterfiend Photo-Video-Media Gallery 32 02-16-2010 02:04 PM
Slammed Walter Photo-Video-Media Gallery 27 02-10-2009 12:30 AM
