Old 02-19-2010, 01:48 PM   #163
+1 !
umm... and you seem to have enough time to post a lot. just saying...
Old 02-19-2010, 01:49 PM   #164
Jason@SportsCar
Originally Posted by kngrsll View Post
i am by no means an expert or professional in racing, but it is a hobby that i have huge passion for. I wouldn't have gotten anywhere without a lot of FREE help from good people, and when i get the occasional chance to give back and help someone out, i try to do it. So comments like that get under my skin. If you don't have time, i totally understand, but i think you can decline to help with a little more courtesy.
On the other side of he coin, I have been at this for a long time and have seen people benefit from my (and others) generosity. Example, helped a guy out with a set of usable tires we no longer needed, he sold them instead of using them as intended. So excuse me if I don't rush off to give away parts. As far as more courtesy, I guess you are entitled to your opinion.
Old 02-19-2010, 01:50 PM   #165
Jason@SportsCar
+1 !
I can post and do my job from my desk. Leaving to pick up, box and ship parts is not part of my daily routine.
Old 02-19-2010, 01:57 PM   #166
kngrsll
Apexing Egg!!
kngrsll's Avatar
people will always dick other people over, that is part of life. I know that, everyone knows that so you aren't onto anything new there. But in my life, i would rather give someone the benefit of the doubt until they prove that they deserve otherwise. And that apparently, is the difference in opinion so there is no point in going on any further on the subject.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 02-19-2010, 03:57 PM   #167
Jason@SportsCar
UPS just dropped off the new clutch, pressure plate and flywheel. This is going to have to wait a few weeks to get installed.
Old 02-21-2010, 10:30 PM   #168
Jason@SportsCar
Fenders are done, looks funny with a 205-50-15 under there.
Old 02-21-2010, 11:13 PM   #169
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
I kinda like the fender flares, but are they necessary with only 205/50's?
Also, are those Rota Flights installed?
Old 02-21-2010, 11:22 PM   #170
Jason@SportsCar
Those tires were for our test day, took them off the ITA Miata we built a few years back, for now they just hold the car up. We will race on a 23-9.5-15 bias slick (which is 10.4" wide).
No, those are Motegi Traklites.
Old 02-22-2010, 01:17 AM   #171
any shots of the install? I'd like to see how much fender you cut away under there.
Old 02-22-2010, 02:04 PM   #172
Jason@SportsCar
In the rear I cut away about .75", and nearly 2" in the front. The rear flares are at the same height as the OE fender, while the fronts are up .5" for extra compression travel.
Old 02-22-2010, 03:58 PM   #173
did your cuts include the bumper (plastic), or only towards the top, taking away metal fender material?
Old 02-22-2010, 04:37 PM   #174
Jason@SportsCar
Both. Just in case we end up staying with the 15"s we wanted to make sure we had lots of clearance - had we committed to 13"s I would have installed the flares without touching the fenders. But we cut away enough material to make up for the weight of the fiberglass flares.
Old 02-22-2010, 05:50 PM   #175
thanks, that is helpful. I don't want to cut my fenders for the 13's unless I have to.
Old 02-22-2010, 05:59 PM   #176
Jason@SportsCar
When we did the math for the 13" slicks, 20-9.5-13 (10.5" wide by 20" dia) we found that the car would hit the ground before it hit the stock fenders. In fact we were only going to be able to lower a .5" from where it is now and be able to maintain what we thought as enough ground clearance.
Your A6s are a little taller (20.9" for the 255), the rear should be fine, the front could be close under compression. If in doubt, pick up some bone yard fenders to hack up.
Old 02-22-2010, 08:45 PM   #177
I'm probably going to raise it a 1/2" and see where that leads me. I'm also putting in the AOE front sway bar, that should help cut the roll just a little bit more.
Old 02-23-2010, 01:34 AM   #178
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
did you manage to find the problem of the misfire on cylinder 1 ?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 02-23-2010, 02:15 PM   #179
Jason@SportsCar
It is being addressed wed and thurs.
Old 02-24-2010, 05:33 PM   #180
Jason@SportsCar
Heading off to the dyno/tuner.
Then up to Toyota in the AM.
Hope we get it all worked out.
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 07:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 10:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 05:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 10:51 AM
