Old 02-21-2010, 12:40 AM   #1
bankrobber
Drives: 2007 Yaris Hatchback
I tried a screwdriver between backing plate but just it barely moved. If I keep doing that the plate will bend. I thought the rear brakes last longer than front?
My front disc is still 50% good. I may have to try the two bolts you mentioned. I dont have any grinding sound from brakes but I got a nail in my tire so after I took it off to put a plug in I decided to check the brakes. If I bend the lip to the backing plate can I just hit it back tight to the drum??
bankrobber is offline   Reply With Quote
Old 02-22-2010, 12:57 PM   #2
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
The object is to adjust the brake shoes away from the drum by turning the star wheel adjuster. If you're bending the backing plate, then you are doing something wrong. After you adjust the shoes away from the drum, then you need to use the two bolt method. If your drums fit as tight as mine did, then they won't come off just by beating or hand pulling. Be wary of using a puller: it must have METRIC threads for the brake drum holes.
Reddog99 is offline   Reply With Quote
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
HELP - Removing rear hub! Doc Zaius DIY / Maintenance / Service 16 05-13-2009 02:52 PM
