★weeaboo★
If your car is overheating in the summer, you should probably get it looked at, as it's cooling system isn't doing it's job. Blah blah blah it's a high pressure area, yadda yadda.
But enough hatin', you used Grade 8 bolts, yeah? I'd hate to see what would happen in a front end collision otherwise.
#2 | |
Form>Function
#3 | |
★weeaboo★
But seriously dude, I wasn't flaming. Get grade 8 bolts if you haven't used them already. In a front end collision it's possible those bolts will shear and send the hood into the pillars and windshield. They're only a few bucks more too. |
#4 | |
Form>Function
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
![]() ![]() ![]() Drives: BSP Yaris LB 2007 Join Date: Apr 2007
The Last Baron
Drives: 09 Polar White HB Join Date: Jun 2009
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires! | UR 19mm sway | |
#8 | |
and btw, NA engines perform better when they're kept hot.
#9 | |
Metric fasteners equal to US grade 8 are metric grade 10.9 +1 > NA engines perform better when they're kept hot yes, engine hot, intake air cool is how to run. these engines run on heat if it was all ceramic and you could keep the motor operable at 500 degrees it would love it. for the current motor, it would have a fine time running at 240 deg if the cooling system was sound and doesn't pop a hose due to neglect. Last edited by 127.0.0.1; 02-24-2010 at 10:46 AM. |
actually it's CLASS 10.9
yes it does, thanks for perpetuating the norm ;)
| C-One Replica Hood. Lets Fix this sucker! | TinyGiant | Cosmetic Modifications (Exterior/Interior) | 56 | 11-09-2009 11:31 PM |
| Micro Image Hood Design Contest | cali yaris | Micro Image | 209 | 10-04-2009 02:49 AM |
| Installed 10mm PG spacers on a 15x7 +25 wheel | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-27-2009 07:10 PM |
| Installed hood deflector, in-channel vent visors and hood seal. | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 16 | 12-20-2008 08:36 AM |
| Before you buy . . . check that hood! | woof | General Yaris / Vitz Discussion | 4 | 12-02-2006 05:14 PM |
