Old 02-23-2010, 01:54 AM   #1
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Originally Posted by Gideon View Post
If your car is overheating in the summer, you should probably get it looked at, as it's cooling system isn't doing it's job. Blah blah blah it's a high pressure area, yadda yadda.
But enough hatin', you used Grade 8 bolts, yeah? I'd hate to see what would happen in a front end collision otherwise.
first of all i never said overheating I only said it gets very hot and if you dont think engines get hotter in florida summers then idk what to tell you. And most mods aren't made to help in collisions so you should be flamin everyone.
Old 02-23-2010, 02:03 AM   #2
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Well if you think this mod will actually cool your engine enough to see any gain whatsoever, that's fine. If you think it looks cool, that's fine too.
But seriously dude, I wasn't flaming. Get grade 8 bolts if you haven't used them already. In a front end collision it's possible those bolts will shear and send the hood into the pillars and windshield. They're only a few bucks more too.
Old 02-23-2010, 11:05 AM   #3
1.5
Form>Function
1.5's Avatar
on a yaris ur completely right its probably not gonna make more than 1hp difference and only if you have other mods already but I like the look and I'll take whatever I can get.
Old 02-23-2010, 11:44 AM   #4
127.0.0.1
it will make 0 horsepower difference
Old 02-23-2010, 09:17 PM   #5
Mead
Drives: BSP Yaris LB 2007
Mead is offline   Reply With Quote
Old 02-24-2010, 12:03 AM   #6
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
Originally Posted by Mead View Post
LMAO!
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
C-One Replica Hood. Lets Fix this sucker! TinyGiant Cosmetic Modifications (Exterior/Interior) 56 11-09-2009 11:31 PM
Micro Image Hood Design Contest cali yaris Micro Image 209 10-04-2009 02:49 AM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
Installed hood deflector, in-channel vent visors and hood seal. IsLNdbOi Cosmetic Modifications (Exterior/Interior) 16 12-20-2008 08:36 AM
Before you buy . . . check that hood! woof General Yaris / Vitz Discussion 4 12-02-2006 05:14 PM
