Old 02-25-2010, 07:46 PM   #1
Happy Little Pony
Drives: 2007 Yaris HB
Don't overlook the obvious. Check the positive and negative battery cables and make sure they are making a good connection. Take the cables loose and scrape the surface of the connectors and the posts of the battery so you can be sure they are clean and there isn't any corrosion interfering with the connection. A small wire brush would work well.
Happy Little Pony is offline   Reply With Quote
Old 02-26-2010, 07:16 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
+1 on that, high humidity/moisture brings out the worst in battery connections,take em off the battery and clean them and the battery terminals till they almost shine. and also clean the grounding connection at the other end of the black ended battery cable.
yaris power steering
seeking recommendations for paintless dent repair sex NY / NJ/ CT / PA 0 02-17-2010 10:08 AM
Seeking wheel advice from someone who KNOWS part II... Chupacabra Wheels, Tires and Suspension Forum sponsored by The Tire Rack 36 12-23-2008 01:13 PM
Seeking wheel advice from someone who KNOWS 09TRD Wheels, Tires and Suspension Forum sponsored by The Tire Rack 60 12-19-2008 03:16 PM
Seeking Hatchback owners to help with parts test why_14 General Yaris / Vitz Discussion 2 12-05-2006 11:16 PM
