Old 12-19-2008, 01:11 PM   #1
09TRD
Drives: 09 Yaris hatch, 09 Z51 'Vette
Seeking wheel advice from someone who KNOWS
I'm looking at Centerlines (forged 6061-T6 alloy). They weigh 14 pounds each and are a bargain.
http://centerlinewheels.com/wheel_de...ehicle&data=33
Anyway, I want a 15" wheel. The size they're offering is a 15" X 7" with a +42 mm offset.
I plan on running a 205/55-15 tire and have the full TRD suspension on the car (springs, shocks, bar).
Is that combination going to give me the clearance I need? I want NO RUBBING AT ALL.
Also, what is the hub diameter for these cars? I've heard 54.1". Is that correct?
I also wanted to verify that the lug spacing is 4 - 100mm.
09TRD is offline
Old 12-19-2008, 01:15 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
you are correct on all counts.. try to pick a "narrow" 205/55.. the fuzion zri was a pretty narrow 205 IIRC
Tamago is offline
Old 12-19-2008, 01:15 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
curious.. what is a "steal" because that's a pretty heavy 15" wheel
Tamago is offline
Old 12-19-2008, 01:17 PM   #4
09TRD
I don't know what you mean when you ask, "What is a steal?"
14 pounds is incredibly light for a 15" X 7" wheel.
Most cast aluminum wheels in that size weigh between 18 and 19 pounds and aren't as strong.
09TRD is offline
Old 12-19-2008, 01:19 PM   #5
09TRD
Will a "wider" 205/55 rub with that wheel?
09TRD is offline
Old 12-19-2008, 01:20 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
12lbs is about average for a 15x7 "light" 15x7
a LIGHT 15x7 weighs under 10lbs
http://edgeracing.com/wheel/7866/
Tamago is offline
Old 12-19-2008, 01:22 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
read up on section widths and tread widths on tirerack.com
i think you should clear a +42 ok with no rubbing issues.. what tire were you looking to get?
Tamago is offline
Old 12-19-2008, 01:22 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
i mean, how much are you getting them for?
Tamago is offline
Old 12-19-2008, 01:22 PM   #9
09TRD
How many ten pound wheels do you see here?
http://www.tirerack.com/wheels/resul...ar=&sort=Brand
19 pounds is about average for the TYPICAL 15 X 6.5" - 15" X 7" gravity cast aluminum wheel.
Racing wheels tend to bend on bad pavement (e.g. potholes, which our roads are full of). I don't want that. I want a robust wheel that's designed to handle the realities of STREET use.
Oh, I'm 45 and have a degree in mechanical engineering.
Go anything else you want to ask?
09TRD is offline
Old 12-19-2008, 01:25 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
19 pounds is about average for the TYPICAL gravity cast 15" X 7":
you're looking in the wrong places then..
www.goodwinracing.com will point you in the direction of quality wheels..
Tamago is offline
Old 12-19-2008, 01:30 PM   #11
09TRD
Call and ask:
I believe they're in the $150 (each) range, which is extremely competitive for a forged 6061-T6 alloy wheel.
09TRD is offline
Old 12-19-2008, 01:31 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
Call and ask:
for forged, absolutely..
but for forged it's on the WAY heavy side
Tamago is offline
Old 12-19-2008, 01:31 PM   #13
09TRD
I am not interested in a RACING WHEEL because they bend on bad pavement.
I want a STREET wheel that will handle potholes and broken pavement, which our roads are packed with.
09TRD is offline
Old 12-19-2008, 01:31 PM   #14
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
I have sub 10lb wheels on our Yaris.
Enkei RPF1s are sub 10lbs if you don't want to spend big $$ on wheels.
a 19lb 15" wheel is insane, i've had 17x8s that were that light.
Russelt3hPirate is offline
Old 12-19-2008, 01:32 PM   #15
09TRD
That's because it is a STRONG wheel designed primarily for use (and abuse) on the street.
Look at that wheels thick spokes; they're "heavy" because they are very strong.
09TRD is offline
Old 12-19-2008, 01:33 PM   #16
09TRD
Originally Posted by Russelt3hPirate View Post
...a 19lb 15" wheel is insane, i've had 17x8s that were that light.
It's also TYPICAL for a gravity cast aluminum wheel in that size.
This FORGED 6061-T6 is very strong; check out the robust size and shape of the spokes.
It is designed primarily as a street wheel with the realities of street driving (ruts, potholes, frost-heaves and expansion joints) in mind.
09TRD is offline
Old 12-19-2008, 01:40 PM   #17
Russelt3hPirate
l33t3st Asshole
so you're saying my 9.9lb wheels will bend if I hit something?
is that a different wheel then the one on the first page?
I'm checking them and they're ugly as sin.
do you like the style? do you like the price?
then buy them, but they are not "light" when compared to the available wheels out there.
Old 12-19-2008, 01:41 PM   #18
09TRD
...Enkei RPF1s are sub 10lbs if you don't want to spend big $$ on wheels.
That's a gravity cast wheel with very thin spokes.
That wheel wouldn't hold up on the roads here in the Northeast.
While it's heavier, the forged and polished Centerline is a vastly stronger, higher quality wheel.
09TRD is offline
Slightly damaged wheel aucorium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 12-06-2008 07:06 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
Wheel Advice caveatipse Cosmetic Modifications (Exterior/Interior) 8 09-19-2007 02:39 AM
Yaris wheel rate ratio (06+) ? dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 07-05-2007 05:43 PM
