#1 | |
![]() Drives: 2007 hatchback Join Date: Feb 2010
How did you deaden the doors? I assume that you used B-Quiet? Did you use other material?
#2 | |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
I did not do anything to replace the moisture barrier, because when I opened the door I did not see any evidence of water having ever leaked in there. It was all clean and dry. - After 62,000 miles with harsh winter weather! I also didn't do anything with the plastic door panel itself, other than replacing broken clips/fasteners with new ones (box of 30 cost $15 in a local upholstery store). The plastic didn't seem to vibrate when I had sound coming out of the door speaker. |
Roadrunner Jr.
That depends on your axis response of the tweeters. Personally, either of those two, I'd probably do the first one. But you really have to hear the results to decide the aiming.
Where are your mids, in the doors? What is your crossover slope and frequency at? Yeah! Dynamat sucks compared to B-Quiet!
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
I have mine like the one's shown in example B , I'm fixin to remount them flat to see what type of result i can get.
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
#5 | |
YES! OK, I'm clue less here, how do I found this out, I got the same components as _SeVeN_ (HIFONICS ZXi6.5C ZEUS 6.5") http://www.yarisworld.com/forums/showthread.php?t=26407 . ![]() .Thanks
. CLA 250, 4MATIC |
swidd...
What kind of rubberized coating did you use in your wheel wells and how did you do it? Thanks .
. CLA 250, 4MATIC |
Uh, $5 bottle of 3M rubberized undercoating spray from Walmart. Tried to spray it myself, but it got real messy, so I took it to one of those drive thru oil change places, bought a tire rotation, and asked if I could apply the rubber coating while they had the tires off. Instead they did the spraying for me, I kept my hands clean, and then I didn't have any cash to tip them.
Cool!
![]() I'm thinking of Spectrum sludge Not cheap, but still going to dig in and learn more of it's properties and pros & cons; Spectrum Sludge is from Second Skin Audio. BTW, I started building my son's playset... This is not going to be easy ![]() .
. CLA 250, 4MATIC |
I did the undercoating way back before much else, and did not notice much improvement if any.
It did make the wheel wells look better though. All black and deep, hiding the cheap plastic and thin metal... But it wears off after a while. |
#10 | |
Audio Junky
if you want both looks & sound improvements... you gotta go with one of the paint on/spray on sound deadeners that comes in 5 gallon buckets for example the second skin spectrum. Everything else either won't put on enough mass, or doesn't cure hard enough. With the duplicor brand spray can stuff (I think $8 a can) I only notice a reduction when comparing a rock flying off my tire into the wheel well at highway speeds... I notice it is slightly muffled compared to when the well was naked (pre-coating). |
Look forward to it! I just slipped in the Alpine PDX-5 into the wire mess, and wholla, awesome sound! CYA!
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
i did 50 ft of edead 45, that got out most rattle made the doors sound much more solid when closing. I do have rattling when sub goes but i honestly dont care as long as i cant hear it inside. The thing i do care about is the front speakers being about as loud on the outside as inside. How would i go about keeping sound inside, those foam things? If all else fails i would just put speakers in the side air vents seeing they point at me, i would get the most sound per volume setting.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
#13 | |
I'll let you know once I get my system running. D.
. CLA 250, 4MATIC |
#14 | |
btw, Eurobeat is pure JDM
#15 | |
Audio Junky
The best option if you don't want any sound to exit the car is to make fiberglass kickpods to install your speakers by your feet. It has the added benefit of allowing you to aim your speakers for better SQ too. In my mazda I had it so that you could have music at about 130dB on the inside, and barely hear it outside of the car... if I cranked it much more then the bass finally would overcome the amount of mat I had... but even then, it wasn't nasty rattle like most people's cars do. |
#16 |
I probably look into what i can fit in the side air vents, or maybe the middle vent which i deem pretty useless for aiming air.
#17 |
Ok, I've been reading and reading all about car audio and passive and active crossovers, and I think I'm getting an idea, thanks to sqcomp and talnlnky for all your help and information. This website it's a very good source of information: http://www.bcae1.com/
I'm done with my son's playset so this week I'm going back to my project. I'll post some ideas of my audio set up and progress with the deadening process. Thanks YarisWorld.com! D.
. CLA 250, 4MATIC |
#18 |
Roadrunner Jr.
That's what this forum is all about mang! I'd like to hear your ideas...
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
