Originally Posted by cast
Thanks for the infor.
Did you use any rubber mat or mass loaded vinyl to cover the floor?
B-Quiet on the floor and lower front firewall... Rubber butyl mat with aluminum foil backing. Very effective, and very easy to work with. A single layer was plenty of added mass on most places.
The cheapest material out there, eDead_45, was not near as effective (if much at all...), the glue was not 'permanent', very minimum mass. It was too thin. But it was extremely clean and easy to apply, and being super cheap, I used it for double and triple layers in the trunk and under the rear seats (large horizontal surfaces).
