#109 | |
![]() Drives: 2007 hatchback Join Date: Feb 2010
You've got this result by only deadening the floor? Did you deaden the doors?
Thanks. Quote:
#110 |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
In short, I deadened everything except the ceiling. Everything was very easy to get to, once I took the seats out.
Approximately sorted by the most effective/giving greatest immediate result: Doors (huge difference) Side walls next to rear seats. (large surface of sheet metal) Lower trunk area below the spare tire. This has thin sheet metal that vibrates. Floors below and in front of foot area (including wheel wells, made a huge difference in engine sound) Hatch (foam) Rear wheel wells (deadener) Rear floor under rear seats and foot area (this area has fairly solid metal and no thin sheet metal that vibrates, no big effect). Center gear shifter area has some open sheet metal that vibrates quite a bit, helps to cover this. |
#111 |
50 sq ft B-Quiet $134
50 sq ft e-Dead $65 Interior carpet roll $10 at Kmart, $15 at Auto Zone (exact same roll) e-dead is not near as good as B-Quiet. B-Quiet is better than Dynamat. All in all very cheap DIY to create comfort. |
#112 | |
. CLA 250, 4MATIC |
#113 |
That is about 100 SF, I got 67.5 ft² of MLV, and I'm running low for the floor and firewall, I just ordered another 25 SF, with a total of about 92 SF, so it's about right what it needs to cover a Yaris Sedan.
. CLA 250, 4MATIC |
#114 |
I'm sorry if I'm been so naive here, what would be the best orientation for tweeters from the images below...
Thank you! .
. CLA 250, 4MATIC |
#115 |
Roadrunner Jr.
That depends on your axis response of the tweeters. Personally, either of those two, I'd probably do the first one. But you really have to hear the results to decide the aiming.
Where are your mids, in the doors? What is your crossover slope and frequency at? Yeah! Dynamat sucks compared to B-Quiet!
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#116 |
I have mine like the one's shown in example B , I'm fixin to remount them flat to see what type of result i can get.
#117 |
Thanks for the infor.
Did you use any rubber mat or mass loaded vinyl to cover the floor? |
#118 | |
I hear your call for pictures, but it all looks stock. I like the way the Yaris looks!! I made a little video instead, but like I said, it doesn't show anything because I put it all together again. I'll keep in mind to take pictures if I disassemble something in the future... http://www.youtube.com/watch?v=gFzLHZN85Rc Last edited by swidd; 04-06-2010 at 01:30 PM. Reason: uploaded video |
#119 | |
The cheapest material out there, eDead_45, was not near as effective (if much at all...), the glue was not 'permanent', very minimum mass. It was too thin. But it was extremely clean and easy to apply, and being super cheap, I used it for double and triple layers in the trunk and under the rear seats (large horizontal surfaces). |
#120 | |
How did you deaden the doors? I assume that you used B-Quiet? Did you use other material?
#121 | |
YES! OK, I'm clue less here, how do I found this out, I got the same components as _SeVeN_ (HIFONICS ZXi6.5C ZEUS 6.5") http://www.yarisworld.com/forums/showthread.php?t=26407 . ![]() .Thanks
. CLA 250, 4MATIC |
#122 |
swidd...
What kind of rubberized coating did you use in your wheel wells and how did you do it? Thanks .
. CLA 250, 4MATIC |
#123 | |
I did not do anything to replace the moisture barrier, because when I opened the door I did not see any evidence of water having ever leaked in there. It was all clean and dry. - After 62,000 miles with harsh winter weather! I also didn't do anything with the plastic door panel itself, other than replacing broken clips/fasteners with new ones (box of 30 cost $15 in a local upholstery store). The plastic didn't seem to vibrate when I had sound coming out of the door speaker. |
#124 |
Uh, $5 bottle of 3M rubberized undercoating spray from Walmart. Tried to spray it myself, but it got real messy, so I took it to one of those drive thru oil change places, bought a tire rotation, and asked if I could apply the rubber coating while they had the tires off. Instead they did the spraying for me, I kept my hands clean, and then I didn't have any cash to tip them.
#125 |
Cool!
![]() I'm thinking of Spectrum sludge Not cheap, but still going to dig in and learn more of it's properties and pros & cons; Spectrum Sludge is from Second Skin Audio. BTW, I started building my son's playset... This is not going to be easy ![]() .
. CLA 250, 4MATIC |
#126 |
I did the undercoating way back before much else, and did not notice much improvement if any.
It did make the wheel wells look better though. All black and deep, hiding the cheap plastic and thin metal... But it wears off after a while. |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
