Old 04-06-2010, 04:23 PM   #11
cast
Drives: 2007 hatchback
Great. I just got all my sound deadening stuff shipped last week. Thanks for the tips.
Originally Posted by swidd View Post
Yep. B-Quiet, about 15 sq ft per door, double layers in the middle/most vibrating areas. Then I stuffed closed cell foam mattress material in the bottom, behind the speaker, and generally all around. And that was it.
I did not do anything to replace the moisture barrier, because when I opened the door I did not see any evidence of water having ever leaked in there. It was all clean and dry. - After 62,000 miles with harsh winter weather!
I also didn't do anything with the plastic door panel itself, other than replacing broken clips/fasteners with new ones (box of 30 cost $15 in a local upholstery store). The plastic didn't seem to vibrate when I had sound coming out of the door speaker.
cast is offline   Reply With Quote
