Old 06-30-2011, 04:54 AM   #1
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Well, the Bit One didn't make an appearance outside the storefront. We talked about placement and wire runs.
There was a lot of work to "finish" the kicks. All I really have to do now is to thread-sert the baffles and rattle can some black the baffles as well. Then it's carpeting for them.
We worked on the sub enclosure as well...
The next part is fleecing the ring. I had to let the wood glue on the supports cure. So I couldn't do too much tonight.
We're hemming and hawing about how to place the amplifiers...whether to angle them or place them horizontally. If we place them horizontally, we have enough space to have the S4b floating in between and "above" the two S2b amps...and it'll look like an entire heat sink...RAWR! :)
The Bit one will be on the cabin side of the pass through is what we're thinking about doing.
What is it going to do for me? The equalizer is 31 band 1/3 octave per output channel (in expert mode) that can be set for each individual channel or for linking the left/right respective channels (i.e. left and right front tweeters). TA adjustments are made in .2 dB increments to + or - 12 dB. Once you have all of your tuning done you simply finalize the setting to the processor and you are good. You can save the setting to you computer (just in case.) you have a total of four setups you can program in. Another nice feature is the Dynamic EQ for the subwoofer. For lack of a better term this is a highly adjustable loudness feature. Crossover Filter types are 12 / 24 / 36 / 48 dB Linkwitz & 6 / 12 / 18 / 24 / 30 / 36 / 42 / 48 dB Butterworth filters.
What does that mean? I'll have steeper crossover slopes, more specific EQ control, and TA control over the deck alone.
― Thomas Paine
Old 06-30-2011, 08:30 AM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thumbs up
Nice! I see you took the flat face approach, very clever and easier to work with.
Bit One: mmm it's getting too complicated I'll leave that for the Pros! I like how easy is for me going through the P-99 features, I understand is not as complex, and like you told me once, it's simple and does a good job.
Keep the pictures coming!
are you giving up the spare tire space?
D.
CLA 250, 4MATIC
Old 06-30-2011, 12:17 PM   #3
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The other nice thing about this kick pod setup for me is that I can have the car wide open and the sound stage stays the same...good for quick demos.
With what I'm doing, I'll need the flexibility that the Bit One gives me. The nice thing though, is if anything bad happens to the piece, I have the source to use.
Yes, I've given up the spare tire. I've got roadside assistance from three places (insurance, Toyota, and the tire place). I'm good.
I think the next pictures will be the finish of the kicks, more work on the sub enclosure, and sometime in the next month, I'll be working the frame for the amps. I'll be using one of the shop guy's cars while the Yaris is being welded on. After the frame is up, then we place the amps and the Bit One.
Fun!
― Thomas Paine
Old 07-01-2011, 03:17 AM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
^I'm going to do the grills on Sunday before these get carpeted.
^ That is a jig...I now make two copies and flush them down into my grills...
You'll see those soon.
― Thomas Paine
Old 07-01-2011, 07:15 AM   #5
derickveliz2
Thumbs up
Very nice!
I keep staring at the HAT logo but I can't find out where it's coming or what is trying to say, do you know the history behind? I'm curious to know.
D.
CLA 250, 4MATIC
Old 07-02-2011, 11:27 AM   #6
sqcomp
Roadrunner Jr.
sqcomp's Avatar
"It is the Christian cross with the stylized circle being the international symbol of unity (“Unbroken Circle”, kind of like a wedding band would signify perfect unity – thus the naming nomenclature of the future Unity series)." - Scott Buwalda
― Thomas Paine
Old 07-04-2011, 03:42 AM   #7
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Hey D i installed them Autotek's today and wow, they sound pretty damn good. The crossover still allows the higher frequencies on the 6.5's through to the tweeter. It's giving a pretty full sound . The Midbass probably isn't as impressive as SQ's or yours but it's good enough for me ! I crossed the mid's over at 120 Hz and they still put out a decent amount of thump !
Old 07-04-2011, 08:49 AM   #8
TOLMACH
Drives: soarer
Was there any special reason for setting the HP filter for your mid woofers at 120 Hz?
Old 07-04-2011, 12:20 PM   #9
_S7V7N_
_S7V7N_'s Avatar
I could Easily set it to pick up the mids at 90 Hz but i liked the way it sounds. It's not a brick wall, it'll pick up stuff lower than 120 Hz. You have a diff suggestion ?
Old 07-05-2011, 03:23 AM   #10
TOLMACH
Drives: soarer
it sure depends on your taste.. most people would cross their mids at 60-80 hz (12 db/oct.)
Old 07-05-2011, 03:32 AM   #11
sqcomp
Roadrunner Jr.
sqcomp's Avatar
In my case, I crossed my L8's at 40 Hz. I have a feeling that these L6SE's may be crossed in the 30's or even lower...
I have plenty of juice to push them, a neat pair of pods that make the L6SE's close to, I not completely, IB.
Mid bass is the key for me.
― Thomas Paine
Old 07-07-2011, 05:39 AM   #12
TOLMACH
Drives: soarer
Do you think you will get good (level of at least F-3) 40 Hz in your kick panel pods? (Asking 'cause never had experience with kicks)
Also, why don't you open a separate thread dedicated to your project? Yours is interesting instal deserving a separate one ))
Old 07-05-2011, 08:30 AM   #13
_S7V7N_
_S7V7N_'s Avatar
I may get an 8 inch sub to handle the midbass, but for now Imma let the 12's handle the 20 - 100 Hz Range.
Old 07-05-2011, 09:08 AM   #14
_S7V7N_
_S7V7N_'s Avatar
I did some searching since you guys set yours different and this was what i found on Crutchfield : http://www.crutchfield.com/S-zucuJnc...overs_faq.html
In a hypothetical car audio system the audio frequencies might be directed as follows:
Low frequencies (say 100 Hz and lower) go to subwoofers.
Midbass speakers get frequencies between 100 and 250 Hz.
Midrange speakers would see frequencies between 250 and 3,000 Hz.
All frequencies above 3,000 are handled by the tweeters.
Keep in mind that the points listed here are not set in stone and do not apply to every car out there. The best crossover points for one vehicle might not be the best for another. It all depends on the speakers being used and the acoustic properties of the car. Most electronic crossovers allow you to choose from several crossover points.
Nothings ever set in stone, Like SQ has them kickass 6.5's and Derick does as well so there crossover points will be a hell of a lot lower than mine. The specs on mine say 60 Hz on the low end, I'd prolly do 60 Hz if i had them in an enclosure with the specified airspace i wouldn't worry to much about over powering them and possibly messing up my voice coils ( which is what i think happend to my component 6.5's ).
Old 07-05-2011, 11:44 AM   #15
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Here's something a little more solid to look at:
― Thomas Paine
Old 07-05-2011, 05:03 PM   #16
xbr3akd0wnx
Meow
Drives: 2008 Yaris, White Hatchback
This is like a map of God's internal organs
Impossible for the likes of me to understand
xbr3akd0wnx is offline   Reply With Quote
Old 07-06-2011, 04:35 AM   #17
sqcomp
Roadrunner Jr.
sqcomp's Avatar
^ This is actually a good reference to have printed out and in front of you when tuning, especially with a 1/3 octave control...I speak from experience.
So D...
I may know someone at my shop with a 700.2. You might call Aaron at the shop and ask him about it.
Spurring you on a little more:
^A blurry closeup of the conceptual on the amp rack. I'm keeping it budgeted tightly. We went as wild as separating the two big amps, reversing them so you see guts. Then we'd place the four channel on a piece of plexi, "floating" and backlight that bad boy.
Instead we're going to show heat sinks on all the amps and have the four channel suspended above the two using a rack and a single piece of MDF that will be carved out on the insides a bit to show off the DD logos on the two big amps while still "floating" the 4 channel on the MDF piece. It'll be routered and painted to match the car. We still might do some lighting behind the 4 channel to show the big boys off.
^Guess what piece makes an appearance? :)
^ 48 dB slopes on all channels left and right, 1/3 octave control on all outputs, and TA down to .2 milis of control. Think about it D...
^I didn't finish tonight on these simply because I'm sending the grill inserts to be CnC'd...
^Rack construction? What rack construction? Pay no attention to the man behind the curtain! That's Jim...He's got a square face...
― Thomas Paine
Old 07-07-2011, 01:56 PM   #18
_S7V7N_
_S7V7N_'s Avatar
He had an awsome thread with lots of pics but deleted it cause people were being ______ . it would be great if that thread was reopened !
