Which "method" are you using to feed it the RPM signal? The Yaris actually has a very good RPM signal, if you use the TACH wire on the OBDII connector. If you are using the method where the GTech looks for ignition noise on the power wire, that would explain it having trouble, as modern cars have good ignition noise isolation.
#2 | |
![]() ![]() Drives: Yaris RS 2009 5DR Join Date: Jul 2009
Well I did know you could use the g-tech without configuring the rpm sensor. Ihave only plugged the g-tech in the 12V output.
Is there a way to connect the g-tech to that signal wire ? |
#3 | |
It looks like it depends on the model. The Gtech Pro EGS has a green wire for tach input. The SS and RS look like they can only read tach from the noise on the power input wire. |
| Turbocharged Dyno Result | cdydjded | Forced Induction Forum | 24 | 08-23-2010 10:54 PM |
| yaris and yaris S | Y@R15 | General Yaris / Vitz Discussion | 54 | 09-14-2009 12:40 PM |
| Source code for Yaris Tachometer | metalshark | DIY / Maintenance / Service | 27 | 04-06-2009 12:41 AM |
| CONSUMER REPORTS : MARCH issue reviews '09 YARIS . | gid | General Yaris / Vitz Discussion | 93 | 01-06-2009 04:10 AM |
