Old 03-05-2010, 02:59 PM   #1
Originally Posted by teddy View Post
I imagine it would be more work (and money) to install the true OEM unit. My instrument cluster doesn't have a cruise indicator, so that would probably need to have been swapped out. There might be other stuff inside that might have needed changing as well.
It is actually far less work to install the OEM one than the Rostra one, but on Yaris prior to 09, you would not have any indicator (unless you used the indicator module that I build for DIYers). I don't believe that swapping the cluster alone would make the indicator work, as I've found that the 07 and 08 ECMs don't send the CAN bus messages to the cluster for turning the cruise indicator(s) on.
Old 03-08-2010, 04:35 AM   #2
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
What type of kit do you make? I want cruise on my 08 manual
liftback. Would be nice to have OEM type install.
Blah, Blah, Blah, Blah
Saggio is offline   Reply With Quote
Old 03-08-2010, 10:51 AM   #3
I don't make a complete kit, but I do make a device that provides an indicator for 06-08 Yaris, which don't have the indicator on the cluster. The link below is a FAQ that I put together to pull all of the info together. It has info about my indicator module:
http://www.yarisworld.com/forums/sho...ght=faq+cruise
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
Cruise Control Question Ranger SVO General Yaris / Vitz Discussion 7 02-06-2010 11:29 AM
Cruise Control bigapl DIY / Maintenance / Service 3 11-05-2009 10:52 PM
Liftback - Easiest Way to Get a Tach and Cruise Control... weeze-dog General Yaris / Vitz Discussion 60 10-20-2006 05:40 PM
