Old 03-05-2010, 02:46 PM   #14
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
Mine is the Rostra one on the left side of the steering column (stationary, like the signal light and wiper stalks). I was kinda disappointed since I was under the impression the Rostra was only something you order and install yourself.
Like CTScott said, it has an indicator directly on it, but it has no way to tell you whether or not you've got it "set". Even worse, the wheel completely blocks it, so I can't see if it's on unless the wheel is turned or I move my head.
My father-in-law's Prius has the OEM cruise with the stalk on the right side of the wheel itself (it turns with the steering wheel). I found this one far more comfortable to use.
I'm not sure where you're getting this 3 handle idea from though, unless you are referring to the
So when the dealer does the installation, it is a aftermarket unit (Rostra)??
Not a genuine Toyota part?? The dealer can't obtain the true OEM unit??
I imagine it would be more work (and money) to install the true OEM unit. My instrument cluster doesn't have a cruise indicator, so that would probably need to have been swapped out. There might be other stuff inside that might have needed changing as well.
teddy is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
Cruise Control Question Ranger SVO General Yaris / Vitz Discussion 7 02-06-2010 11:29 AM
Cruise Control bigapl DIY / Maintenance / Service 3 11-05-2009 10:52 PM
Liftback - Easiest Way to Get a Tach and Cruise Control... weeze-dog General Yaris / Vitz Discussion 60 10-20-2006 05:40 PM
