Old 03-09-2010, 11:40 PM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
Originally Posted by sbergman27 View Post
You mean... after you started consciously aiming toward decelerating over a longer distance and using the brakes less?
Reality check: Consider that if you manage to stay in DFCO mode for a full hour, you've only saved about 0.2 gallons of fuel (specifically due to DFCO) since the Yaris' engine uses about 0.2 gal/hr at idle. To get a 10% improvement in fuel economy over the course of a tank of gas, you would have to spend over 5.5 *hours* in DFCO mode. Do you think that you are managing that much?
-Steve Bergman
You have quite the attitude about all of this, Steve. DFCO may have existed for a while but it is/was far from common knowledge. Just because you knew about it earlier doesn't turn the rest of us into bumbling idiots, or negate the uniqueness of me discovering and proving it on my own.
While what you say may be technically accurate you completely overlook the fact that fuel efficiency techniques bleed into and overlap each other. It is nigh impossible to extricate an intertwined technique from its siblings, so striving towards DFCO usage will invariably lead to more efficient usage of brakes and deceleration and downhill throttle control while simultaneously making the driver more FE-aware in general. If it is easier for folks to understand that whole set of skills simply as DFCO usage please let them be.
Please try to look beyond the trees so that you can see the forest. Getting caught up in the minutiae of an easy-to-understand and easy-to-use technique will do no one any good.
- Brian
Share the Road
Old 03-09-2010, 11:58 PM   #2
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
I believe in accuracy, and in correcting misleading and/or erroneous information. What you discovered is that brakes turn kinetic energy into waste heat and that conserving kinetic energy helps fuel economy. DFCO is a relatively minor enhancement to that.
My clarifications in no way reduce the value of the information you have provided. But having a more accurate grounding in *why* it works will allow people to make more effective use of it.
That's not "attitude". It's a simple respect for truth. I believe in calling a spade a spade.
-Steve
sbergman27 is offline   Reply With Quote
low gas mileage? yrsdrgn General Yaris / Vitz Discussion 30 01-17-2019 03:26 AM
Synthetic oil MPG boost since change Yaris Dick General Yaris / Vitz Discussion 29 09-15-2007 08:15 PM
Increased MPG or HP anyone???? slvryaris Performance Modifications 55 05-27-2007 10:49 AM
MPG trackers acrbill General Yaris / Vitz Discussion 11 01-01-2007 07:34 PM
