Old 03-13-2010, 12:32 PM   #10
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
cool, good work. at home now... i can see that box is made of particle board... ehhh no wonder it chipped. In the future, anytime the screw holes strip you can just fill in those screw holes with glue, or sealant of some kind (silicon works well) and then just rotate the sub 1" and drill new holes. I like to use a 7/64" bit, but and a 1/8" bit works well too. Then just find some drywall screws... Drywall screws are best in MDF & particle board because the spiral part of it extends out farther, meaning there's less chance to strip the hole.
you said you were going to wire the subs in parallel, I'm guessing they are 4ohm coils... so you'd be running 2 ohms per channel on that amp (the amp has 2 channels right?).... be careful with the gain and volume knob as you may get more power than those subs can handle. Remember 150rms....
I like the job with the liquid nails... it should work well around the seams of the box and the terminal cup... it'll help a bit around the sub hole, but really.... I think for chips, the best patch may actually to use some fiberglass body filler like Bondo or rage gold... I wouldn't worry about doing that tho sense this isn't the highest quality box and body filler isn't cheap.
Blown Fuse - Stereo !?! click.mine In Car Entertainment + Electronics (audio / video / alarm) 16 10-05-2017 08:35 AM
Stereo Upgrades....what to do!? gravylegs In Car Entertainment + Electronics (audio / video / alarm) 39 02-28-2010 12:58 PM
FS: Bluetooth Stereo Headphones and Ipod Transmittor Sabretooth Items for Sale by private party 3 05-06-2009 05:59 AM
Install sedan integrated stereo in hatchback? atebit In Car Entertainment + Electronics (audio / video / alarm) 6 05-22-2007 05:25 PM
Stereo finished! Spades In Car Entertainment + Electronics (audio / video / alarm) 6 12-20-2006 10:17 PM
