Old 03-15-2010, 04:49 PM   #1
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
Originally Posted by Loren View Post
It's a "learning" system. You may want to try resetting it to default so that it can learn YOUR driving habits.
My accelerator pedal is heuristic!?!?!?!?!?!?
Oh my. I was not expecting that.
What's the easiest way to go back to the defaults? I've driven 2-1/2 weeks and about 6,000 miles (yeah, I drive a lot) and have not noticed any change in its behavior.
-Steve
Edit: The *very* first bit of pedal travel does not seem to get any response at all, so I push it a little farther (not much) until I do get a response. When it kicks in, that's when it seems overly sensitive. Is that what you are referring to?
sbergman27 is offline   Reply With Quote
Old 03-15-2010, 04:57 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
The only learning behavior I've noticed is in transmission shift points. It trains very quickly, usually in a day's driving. No special action is needed for resetting, it adjusts to your driving style as you go. Thrash it and it'll wind up farther before shifting and downshift quicker. Drive it like a hypermiler and it'll lug along shifting when it really has to.
Old 03-15-2010, 04:58 PM   #3
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
-Steve
Disconnect the battery for a period of time (just how long I'm not sure as I've seen many different values mentioned.)
FWIW - Mine is a manual and I find just the opposite in that I have to goose it a bit to avoid stalling when letting the clutch out. I've considered doing the reset and stomping on it for a while to see if the ECU adapts to the new style. Let us know how your experiment works out.
Toyota Recalls auxmike General Yaris / Vitz Discussion 535 02-25-2021 06:13 PM
Did Toyota Prius Driver Fake Unintended Acceleration? JBougie Off-topic / Other Cars / Everything else Discussions 33 03-15-2010 11:24 AM
Yaris Acceleration Decays cheche DIY / Maintenance / Service 0 07-08-2009 08:34 AM
stick vs. auto acceleration abcando General Yaris / Vitz Discussion 36 04-08-2009 08:06 AM
more acceleration with smaller tire diameter? Stiv Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-28-2009 07:50 AM
