Old 03-17-2010, 02:59 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by marlondog View Post
As far as wheels, you shouldn't go wider than 7''(15x7,16x7,17x7) with a 38 offset(38-45). You will still need to add adjustable camber bolts to the front to tuck them in and to keep from busting up your fenders(anything from 38-41 will need camber). !
there are dozens of members here running +30mm offsets here, with no fender problems. don't regurgitate internet knowledge..
Old 03-17-2010, 04:45 PM   #2
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Like that guy with the blue Yaris with the Racing Dynamics and the 13mm hub spacers? He nearly took off his front fender doing autocross. I think he was running 30 offset wheels.
As far as what I know, it's based on "experimenting" and not having a good time fixing it(i.e tires,wheels,camber). Been there,done that!
Alot of people will disregard what someone says, because they don't want to hear no. I don't know which other way to say it.
If you want to spend time and money changing out tires and wheels,adjusting camber,changing out shocks and springs, pulling and rolling fenders,stretching out tires to fit on wheels they're not designed for, then go for it!
No one is trying to rain on anyone's parade. If people are so sure about it, then they shouldn't ask questions. If you get told it's a pita, believe it.If they say it's easy, don't believe it.
marlondog is offline   Reply With Quote
Old 03-17-2010, 07:05 PM   #3
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
Anyways, I'm running +37 up front with +24 in the rear (PG 13mm spacers), 15x7 with 195/55/15 tires on DF springs. It rubs occasionally in the rear when loaded down and I hit a bump too fast. Aside from that everything is good.
I'll try to get photos but i don't really care enough to take the time to do it.
(dick measuring info goes here)
aeipee13 is offline   Reply With Quote
Old 03-17-2010, 07:14 PM   #4
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
rolled or cut fenders?
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 10:43 PM
End of a decade? yaris-me Off-topic / Other Cars / Everything else Discussions 4 12-31-2009 12:12 PM
aftermarket front sway bar end links? jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-08-2009 11:26 PM
Review: Adjustable Sway Bar End Links m911gt Performance Modifications 9 04-29-2009 09:25 AM
Questions, questions... littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-21-2006 01:42 PM
