Old 04-15-2009, 11:12 PM   #1
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
Review: Adjustable Sway Bar End Links
I recently received a pair of adjustable sway bar end links from turboyaris and have had a chance to drive about 600 miles with them installed. All of the components of the end links appear to be of high quality, the heims were free to rotate without any problems and the threading was very nice on both the bolts and rods themselves. Since the rods are hexagonal, the ends were easy to tighten or loosen and ultimately, adjust. The end links were simple to install, in fact, even easier than removing the stock set since an allen key is not required. While driving I cannot honestly say I feel much of a difference in handling, but some of the rubbing I had previously experienced had gone away. Since installing the end links, I have inspected the heims and there appears to be no binding and they still have great mobility.
I would recommend this product to anyone looking for an easy to install suspension upgrade at an affordable price. If you are interested, please PM turboyaris.
Wanted: Forced Induction
Old 04-15-2009, 11:18 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
I am still awaiting mine =)
Old 04-15-2009, 11:21 PM   #3
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Very nice. How much? Will they work with stock shocks?
Old 04-15-2009, 11:24 PM   #4
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
The set I have are nickel plated, I believe the next batch he ships out will be made with stainless steel. The group buy price is $125, PM turboyaris for details. Yes, they will work great with stock suspension.
Old 04-16-2009, 12:52 AM   #5
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
actually they are only $120 shipped to you.
and m911 yours are actually just standard uncoated steel, and you were correct though in saying the group buy hex is stainless
And YarisSedan, as I posted in the group buy post, I received the wrong heims from the manufacturer, so I'm awaiting a shipment of new heims... The good news for you.... They are FK Bearings instead of Midwest control, (a little better quality)
The group buy post is located here http://www.yarisworld.com/forums/showthread.php?t=15771
turboyaris is offline   Reply With Quote
Old 04-16-2009, 12:53 AM   #6
turboyaris
and yes, just to reiterate, they work with stock suspension, and any other coilovers that retain stock mounts for the end links.
Old 04-18-2009, 06:43 PM   #7
m922gt, have you tried tightening them up? You mention that you couldn't feel a difference, but then describe them as a suspension upgrade. I'd like to hear someone describe the difference they make in a real-world driving experience.
(I'll do that when I get them, but meanwhile....? )
Old 04-19-2009, 11:13 AM   #8
Deltasix
Deltasix's Avatar
Drives: '07 Liftback: Work in Progress
Send a message via AIM to Deltasix
+1
I too would like to here what they are like tightened up
"The basis of optimism is sheer terror."
Deltasix is offline   Reply With Quote
Old 04-19-2009, 12:03 PM   #9
YarisSedan
When adjusting these you want it to be just gently snug when all 4 tires are on the ground and prefferably with the driver sitting in the car as well i would assume?
Old 04-29-2009, 09:25 AM   #10
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
Update: I have put about 1,100 miles on the sway bar end links and I have had no problems with them.
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
adjustable sway bar end links group buy!!! turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 51 06-13-2012 11:49 AM
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 10:43 PM
Gauging Interest: Whiteline Front/Back Adjustable Sway Bars RaptorRacing Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 12-15-2009 04:23 AM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
