#1 | |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
And cycling the ignition is not a "distraction". Your eyes don't leave the road, you still have assisted steering, and the brakes are good for 4-5 touches. Seriously, of all the things that one can gripe on for being a distraction while driving, cycling the ignition is at the bottom of my list. There is a time and place for DFCO usage but it has two severe limitations: 1) It steals momentum. 2) The engine uses fuel again once any of its conditions are no longer met. Coasting with the engine off is much more efficient in all aspects when you know you'll be coming to a stop for a while, or when you want to maintain more momentum in between the times you let the engine run.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
| yaris won't start, engine truns over but won't start. | zara616 | General Yaris / Vitz Discussion | 16 | 09-05-2021 11:39 AM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| Help! Car won't start... | Toyota Kel | General Yaris / Vitz Discussion | 4 | 03-01-2010 04:44 PM |
| Yaris does not start | jake002 | DIY / Maintenance / Service | 21 | 01-05-2010 08:53 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
