#1 |
Drives: Toyota Yaris Join Date: Mar 2010
Help! Car won't start...
I'm a new driver and have had my Yaris for about 6 months. It a 2006 manual with stop/start ignition.
i tried to take the car for a spin over the weekend and it wouldn't start. Press the cluth and the ignition button, and it just make a quiet wheezing noise and refuses to start. 2 warning lights appear for a few seconds, the battery and the oil level. But they always appear when I start the engine. After about 5-10 seconds, all the normal lights on the dash turn on and the engine sounds even worse. The car's been recalled by Toyota to get the accelerator fault fixed, and I can't even drive it to the garage... Does anyone have any advice on if I can get the car started by myself? I don't want to havea to call a breakdown service if I can help it. Thanks very much!!! ![]() Kel P.S. If it makes a difference, it's parked facing downhill on a steep slope. |
it may be your battery if so you are in luck it's parked facing downhill on a steep slope so you just need to clutch start. if the battery is dead the car will make a clicking noise or even nothing, you may even just need to spin the stearing wheel a bit to click out of lock. To clutch start you turn the key all the way on,make suer you are on a clear hill with no other cars around stick it in 2nd roll down the hill till you get to about 20-30kph then quickly lift your foot from the clutch as you hit the gas and the car will start be sure to leave it running to recharge battery, i had this problem a few times one reason was that i changed the lights in the car to leds and the car did not like it much and the stock battery is not very powerful so i put in a better one that lasts longer so
#3 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Sedan Join Date: Oct 2008
What wheezing noise is typical of what a starter makes when its not engaging. But your car being new that dosnt make sense. You can try taping on it with a rubber malet sometimes that works.
#4 |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
It's nto new, it's an 06. IT might be dead? When you flip the light switch do the headlights come on? If not you have a dead battery
#5 |
![]() ![]() ![]() Drives: S Flint Mica Join Date: May 2006
I didn't think the Yaris had been recalled for the accelerator problem.
| KCALB SIRAY - Photo Scavenger Hunt | KCALB SIRAY | Photo-Video-Media Gallery | 5 | 03-02-2009 10:44 AM |
| New car shopping - long post | littlecarlove | General Yaris / Vitz Discussion | 19 | 11-01-2006 10:58 PM |
