Old 03-19-2010, 03:11 PM   #1
1stToyota
1stToyota's Avatar
And I hope that you also realize that if you lose your power assist you're brakes aren't nearly as effective. By the time you figure out that you've lost the assist and you'll have to press a lot harder it could be too late. Oh well.
And you lost vacuum to your booster at the track, or are you experiencing brake fade from overuse?
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 03-19-2010, 04:24 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I've had both. At autocrosses, the brakes never get hot enough to pad fade (with upgraded pads... the stock pads would fade regularly) or boil fluid. I left-foot-brake when I autocross, so I'm on and off the brakes a lot more than most people. Sometimes near the end of a run, I'll run out of boost. Last weekend, it was happening at exactly the same place on every run. Just one of those things.
Pad fade used to happen at the track a lot until I installed brake cooling ducts.
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
Help! Car won't start... Toyota Kel General Yaris / Vitz Discussion 4 03-01-2010 04:44 PM
Yaris does not start jake002 DIY / Maintenance / Service 21 01-05-2010 08:53 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
