#1 | |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
Safety isn't about what you expect. It's about what you don't and can't expect. And it only takes once. Think about it. World energy usage, from fossil fuels, is about 400 exajoules per year. That's equivalent to about 3.2 trillion gallons of gasoline per year. About 100,000 gallons per second. The Yaris uses about 1/30th of a teaspoon of gasoline per second at idle. About 2 thousandths of a millionth of the average world rate of consumption. And, of course, the difference between coasting in 'D' and coasting with the engine off is effectively a fraction of that 1/30th of a teaspoon. Just the difference from engine braking. You can tap the accelerator from time to time to maintain speed, remaining in DFCO most of the time. I'm going to guess that the difference comes out to be about 1/300th of a teaspoon per second. (This assumes that engine braking is costing you about 10%. Works out to about a 3 mph/sec deceleration with your foot off the pedal. Season to taste.) Is it really worth it to save 1/300th of a teaspoon per second? 1/4000th of a gallon per minute? -Steve Last edited by sbergman27; 03-30-2010 at 07:07 PM. |
#2 | |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
The less each of us uses of it, and the more responsibly each of us uses it, the less the world will need each day. The less the world needs each day the less pressure there is on the whole human and ecological systems. The way I see it each of us is either part of the problem or part of the solution, and by reducing my demand for oil I feel that I am not part of the problem. All the scaremongering and fuzzy math (the output of an equation is only as good as the input, and you continually miss a huge chunk of the input) in the world changes none of this. ---------- We know that some of you don't care for hypermiling but, frankly, I am getting sick and tired of the scare tactics and gloom and doom coming out each and every time anyone posts anything about a hypermiling technique. You don't see us FE types parading into the Performance forum and bashing speeding or track days or spending huge amounts of money for minuscule gains. You don't see us pestering the Cosmetic forum about the things we think are silly, or making fun of how much money is spent on those types of things. We expect the same in return here in the Fuel Economy forum. If you have nothing positive to contribute to a thread then please spend your time elsewhere. If you can't stomach conversations about hypermiling then please spend your time elsewhere. This is indeed the Fuel Economy forum,and hypermiling is a large part of that. Please get over it or move on.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#3 | |
Drives: 07 sedan Join Date: Mar 2010
People DO bash speeding threads. Going to the track and modding your car is safe and legal, but if you feel the need to bash, go ahead. Turning your vehicle off is not safe, and not legal in most states as has been pointed out. It seems the only person in this thread that "can't stomach" the conversation is you, as everyone else is staying on topic and bringing up valid points which you choose to ignore. |
| yaris won't start, engine truns over but won't start. | zara616 | General Yaris / Vitz Discussion | 16 | 09-05-2021 11:39 AM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| Help! Car won't start... | Toyota Kel | General Yaris / Vitz Discussion | 4 | 03-01-2010 04:44 PM |
| Yaris does not start | jake002 | DIY / Maintenance / Service | 21 | 01-05-2010 08:53 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
