Old 04-04-2010, 11:06 AM   #1
hondakiller99
Drives: 05 Scion xA
if im not mistaken , isntthe TCS run throught the steering wheel? like the actuall TCS on my car, i know its a scion but its a idea, is always off cuz i did a steering wheel swap with a quick realease hub and i no longer have the option for no traction control, which IMO sucks, cuz when it rains out here i have no chance and traction when i hit a puddle that is un-avoidable.... IMO no traction is mmeehh lol
hondakiller99 is offline   Reply With Quote
Old 04-04-2010, 04:27 PM   #2
Yaris#2
Yaris#2's Avatar
Drives: 2010 5dr hatchback manual
I think this is it. It works on my 2010 5dr manual just fine
http://www.yarisworld.com/forums/sho...&highlight=vsc
Yaris#2 is offline   Reply With Quote
Old 12-20-2010, 02:28 PM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
^^i second that^^
Old 12-20-2010, 02:54 PM   #4
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
pull the 30a fuse for the abs/vsc in engine comp fuse block jus gotta deal with the abs/brake and vsc light on dash but shit don't matter to me. small price to pay to see the faces of people when i peelout with my little yaris leaving a huge cloud of tire smoke and burned rubber on the asphalt FTW!
OTA'sTOY is offline   Reply With Quote
Old 12-21-2010, 06:37 AM   #5
SAV912
Pirate Yaaaaris
SAV912's Avatar
You're not leaving a huge cloud of anything except clutch smoke unless you tied your car to a telephone pole. 106hp and even the shittiest tires don't exert plumes of smoke even if you dump the clutch at redline. Good luck getting warranty work done on it too with intentionally missing fuses. But hey, shit don't matter to you.
That said, I find it hilarious that a car a sneeze away from double-digit hp needs traction control. Glad I got the '09. Yes to ABS, pass to TC.
-SAV
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 12-21-2010, 11:05 AM   #6
anteup0527
Drives: 2010 Toyota Yaris
What would the benefits be for turning off the TC? Thanks.
anteup0527 is offline   Reply With Quote
Old 12-21-2010, 11:50 PM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
-SAV
obviously you have absolutely no idea what a emergency brake is. You really should figure that one out, they are kinda important.
Colin Chapman disciple
Old 12-22-2010, 08:14 AM   #8
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
E-brake is failsauce, it doesn't even hold the wheels.
Midnight Drifter is offline   Reply With Quote
Old 12-23-2010, 12:48 AM   #9
SAV912
Pirate Yaaaaris
SAV912's Avatar
Yes, I have an awesome idea what an e-brake is. Seeing how mine is a manual, I use it every day. And using it for anything other than holding the car still results in beeping from the dash because it sucks at holding back even the small amount of power a Yaris engine produces.
Yeah. They are important. I'm sure using it for burnouts is top priority.
-SAV
Georgia Bulldogs!
Old 12-20-2010, 05:30 PM   #10
ilikerice
ilikerice's Avatar
^1 tire spinning?^ hope u gots a limited slip
Old 12-21-2010, 01:00 AM   #11
yaris2010RS
yaris2010RS's Avatar
my 2010 yaris M/T has the on off switch that i use regularly
Old 12-21-2010, 11:49 AM   #12
ilikerice
ilikerice's Avatar
track use only.. lol.. i turn it off only when i autocross..
and also to dyno it..
and if you wanna peel out everywhere u go.. personal preference i think
Old 12-22-2010, 08:34 AM   #13
ilikerice
ilikerice's Avatar
yea.. handbrake sux on the yaris.. wish the rear disc conversion adapted some kinda hinge to hook the handbrake cable instead of keeping the drum shoes for handbrake..
Old 12-22-2010, 11:42 PM   #14
yaris2010RS
either urs isnt adjusted right or ur not pulling on it hard enough. i lock up my rear wheels when ever i want on what ever i want....
but the e-brake having the ability to hold the rear wheels.....what does this have to do with traction control removal?
Old 12-23-2010, 03:42 AM   #15
ilikerice
ilikerice's Avatar
aggreed, this thread has gone off course of the OP, i do believe my hand brake is not tight enough for the things i sometimes do. yes, it hold the car in place while ur stopped. but i use it also to power slide, well, i tried in the yaris but just doesnt happen with these drum brakes (could tighten the cables). the crx with the rear integra disc conversion i am able to easily powerslide with the flick of the handbrake.
and yes, this is not conventional driving and this does not increase your track time in the least. but i do it to get laughs and many are impressed that a front wheel car can "drift" i guess.. we dont have the luxury of droping the clutch before a turn to get the rear end to slide, therefore we rely on the handbrake. ill end my handbrake talk now.
seems like some rare models in 09 have the vsc/trac switch.. maybe earlier production of that year before the did away completly with that feature in the US models *shrugs*
Old 12-23-2010, 04:09 PM   #16
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
i wonder if its possible to add that traction control button on ?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
any how to's to disengage the traction control? OTA'sTOY DIY / Maintenance / Service 8 04-06-2010 04:26 PM
Traction Control ??? pennystocks General Yaris / Vitz Discussion 6 09-12-2006 07:14 AM
