#1 | |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
#2 | |
Is now a Corolla S Owner
Just for the purpose of demonstration, let's say I get 37 MPG on my Yaris, but to be sure I don't run out of gas, I use 35 MPG for calculating purposes. Also, I assume that I only have ten gallons of gas available to use after a fill-up instead of 11 gallons. This is another way to be conservative in determining how many more miles I can drive before filling up. OK, 10 gallons of gas times 35 miles per gallon means that I should safely be able to drive 350 miles before filling up again. I reset the trip odometer to 0 at the time I fill up the car, and when I see that I am getting close to 350 miles, I fill up again. In reality I could go further than that, but I am not one to push the limits. I see no point in trying to drain the tank down to fumes before filling up again. I don't want to run out of gas somewhere. As far as figuring MPG, the only way that I know of to do that is to divide the number of miles driven since the last fill-up by the number of gallons required to fill the tank on the current fill-up. That's what MPG is by definition. Tom |
#3 | |
#4 | |
The only reason I use the method I described is just as a means of knowing approximately how many more miles I can go before filling up. By no means do I use it to try to get the last drop of gas used before filling up. I think it is silly to do that. I fill up on the way in to work at a gas station near my workplace. I might use that range estimation method to decide if I should fill up today or if I can get home and back to work tomorrow. If I think it is going to be too close, I will fill up today and not take the chance. Tom P.S. I have kept track of every gallon of gas that I have put in my Yaris since I bought it one year ago. The average number of gallons that I have bought per fill-up is 7.822, and the most it ever took to fill it was 9.50 gallons, so I am not trying to run the tank too low. |
#5 | |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
-Steve |
#6 | |
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| gas gauge | cali yaris | Performance Modifications | 19 | 01-16-2009 08:41 PM |
| gas gauge issue | Bretsuaz | General Yaris / Vitz Discussion | 2 | 06-14-2007 11:00 PM |
| gas gauge and wiper jet spray | Adriaan | DIY / Maintenance / Service | 4 | 06-03-2007 02:13 AM |
| Free gas for any vehicle. | ketel0ne | General Yaris / Vitz Discussion | 4 | 09-19-2006 08:07 AM |
