![]() Drives: 2010 AT 5dr Liftback Join Date: Jan 2010
Guys I really want to do this, I just bought a 2010 AT Mexican Yaris from the local dealer, but I don´t know if there´s any difference between mexican, american or canadian yaris. Am really close to the Arizona Border so I can easily buy the required parts but am afraid my ECM is not compatible, any ideas?
#2 | |
If you shine a flashlight around on your instrument cluster, do you see the two icons for cruise control? |
Ok, thanks for the info CTScott, am gonna check voltage and instrument cluster before start buying stuff ...So many things to do with this yaris.
#4 | |
My instrument cluster has the two icons for CC, my ECM part number is 89661-52G71, and I have a reason to believe that mexican and canadian yaris use the same specs because there's a sticker on my door with a canadian logo. The canadian sticker surprised me, apparently all mexican Yaris got it, a friend of mine has a sedan and the same sticker is there. ![]() What do you think? can this be posible? If that is correct and I have the canadian version I would like to buy one of your cc kits you sell and give this a shot. Thanks for the help. |
#5 | |
I just ran your VIN through the EPC and your car is actually a Canada spec, not Mexico spec Yaris, so cruise will definitely work for you. I suspect that even for Mexico Spec cars that it will work as well.
#6 | |
![]() thanks for the quick reply. are you still selling the cheap OEM cruise control stalk & connector cable? I have a US based shipping address in Nogales, Arizona |
Yes. I still have the Stalks with CC wire and mounting screws for $40, as well as the pins needed for 06-08. Theoretically your 2010 AT only needs the stalk, since the US and Canadian 09+ Yaris have the wiring in place, but you may want to take a peek at the ECM connector and the spiral cable connector to be sure.
#8 | |
Can't wait to do this, If the wiring is already in place a friend of mine with a 08' sedan can use the extra wire. Thanks for the help. |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 12:59 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 11:12 PM |
