Old 10-08-2011, 09:54 PM   #1
carlosgil5
Drives: 2010 AT 5dr Liftback
I just ran your VIN through the EPC and your car is actually a Canada spec, not Mexico spec Yaris, so cruise will definitely work for you. I suspect that even for Mexico Spec cars that it will work as well.
thanks for the quick reply.
are you still selling the cheap OEM cruise control stalk & connector cable?
I have a US based shipping address in Nogales, Arizona
carlosgil5 is offline   Reply With Quote
Old 10-08-2011, 09:58 PM   #2
Yes. I still have the Stalks with CC wire and mounting screws for $40, as well as the pins needed for 06-08. Theoretically your 2010 AT only needs the stalk, since the US and Canadian 09+ Yaris have the wiring in place, but you may want to take a peek at the ECM connector and the spiral cable connector to be sure.
Old 10-09-2011, 02:58 PM   #3
carlosgil5
Please PM me your info.
Can't wait to do this, If the wiring is already in place a friend of mine with a 08' sedan can use the extra wire.
Thanks for the help.
Old 10-16-2011, 03:28 PM   #4
carlosgil5
Well, am in trouble, I picked up the package, thanks for the kit, everything came in time and as expected.
Drilled the cover, installed the stalk with the wire, did a road test and it's not working.
I definitely need help here guys.
What do you think, the 06-08 method?
Looks like this is going to be a learning experience for the people with Yaris bought in Mexico.
Old 10-16-2011, 06:07 PM   #5
Can you take a measurement on the wire that goes to the ECM pin. With the ignition on and none of the stalk switches pressed, it should read +12V.
Old 10-17-2011, 03:38 AM   #6
carlosgil5
I could not get any measurement I have one of those little harness plugs in the hole where pin 40 would be.
This are the connections under my steering wheel.
there's no blue and no brown wire.
This is my cluster showing the cc icons.
So I have to run the wire from which hole in the connector?
What else do I have to do, I already drilled the cover, plugged the stalk wire and bolted the OEM stalk.
I was really hoping my '10 AT had all the wires in place. Not at all.
Old 10-17-2011, 06:35 AM   #7
So, you definitely need to add the connector D3 pins. The other question is if the ECM connector A21, pin 40 is present? On Puerto Rico spec cars, it is, but the D3 pins are not.
