Old 04-14-2010, 10:25 PM   #1
Originally Posted by carlosgil5 View Post
Guys I really want to do this, I just bought a 2010 AT Mexican Yaris from the local dealer, but I don´t know if there´s any difference between mexican, american or canadian yaris. Am really close to the Arizona Border so I can easily buy the required parts but am afraid my ECM is not compatible, any ideas?
Mexican Yaris get a different ECM than US and Canadian ones, so you would definitely have to test it to see. The place to start is to measure the voltage on the ECM pin 40, with the ignition in the on position. If you see 12 Volts on that pin, then there's a good chance that it will work.
If you shine a flashlight around on your instrument cluster, do you see the two icons for cruise control?
Old 04-15-2010, 11:26 AM   #2
carlosgil5
Drives: 2010 AT 5dr Liftback
Ok, thanks for the info CTScott, am gonna check voltage and instrument cluster before start buying stuff ...So many things to do with this yaris.
carlosgil5 is offline   Reply With Quote
Old 10-08-2011, 06:25 PM   #3
carlosgil5
Well, I know it's been a while since I ask for your help, a 4 hour drive remind me I need this mod. Check this out please.
My instrument cluster has the two icons for CC, my ECM part number is 89661-52G71, and I have a reason to believe that mexican and canadian yaris use the same specs because there's a sticker on my door with a canadian logo.
The canadian sticker surprised me, apparently all mexican Yaris got it, a friend of mine has a sedan and the same sticker is there.
What do you think? can this be posible?
If that is correct and I have the canadian version I would like to buy one of your cc kits you sell and give this a shot.
Thanks for the help.
Old 10-08-2011, 09:15 PM   #4
I just ran your VIN through the EPC and your car is actually a Canada spec, not Mexico spec Yaris, so cruise will definitely work for you. I suspect that even for Mexico Spec cars that it will work as well.
Old 10-08-2011, 09:54 PM   #5
carlosgil5
thanks for the quick reply.
are you still selling the cheap OEM cruise control stalk & connector cable?
I have a US based shipping address in Nogales, Arizona
Old 10-08-2011, 09:58 PM   #6
Yes. I still have the Stalks with CC wire and mounting screws for $40, as well as the pins needed for 06-08. Theoretically your 2010 AT only needs the stalk, since the US and Canadian 09+ Yaris have the wiring in place, but you may want to take a peek at the ECM connector and the spiral cable connector to be sure.
Old 10-09-2011, 02:58 PM   #7
carlosgil5
Please PM me your info.
Can't wait to do this, If the wiring is already in place a friend of mine with a 08' sedan can use the extra wire.
Old 10-16-2011, 03:28 PM   #8
carlosgil5
Well, am in trouble, I picked up the package, thanks for the kit, everything came in time and as expected.
Drilled the cover, installed the stalk with the wire, did a road test and it's not working.
I definitely need help here guys.
What do you think, the 06-08 method?
Looks like this is going to be a learning experience for the people with Yaris bought in Mexico.
