#19 | |
Is now a Corolla S Owner
The only reason I use the method I described is just as a means of knowing approximately how many more miles I can go before filling up. By no means do I use it to try to get the last drop of gas used before filling up. I think it is silly to do that. I fill up on the way in to work at a gas station near my workplace. I might use that range estimation method to decide if I should fill up today or if I can get home and back to work tomorrow. If I think it is going to be too close, I will fill up today and not take the chance. Tom P.S. I have kept track of every gallon of gas that I have put in my Yaris since I bought it one year ago. The average number of gallons that I have bought per fill-up is 7.822, and the most it ever took to fill it was 9.50 gallons, so I am not trying to run the tank too low. |
#20 |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
One more time: here I am, 390kms on the clock, 2 bars missing off the gauge. Nice piece of (worthless) equipment, that gas gauge...
#21 | |
![]() ![]() Drives: 07 5 door Hatchback Join Date: Jul 2007
Like it's been said before, when you reach 2-3 bars left, fill up. |
#22 | |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
I've watched economy cars evolve from the most basic of conveyances into the grand carriages which we expect to inhabit the bottom rung today. If buyers of the bottom rung of cars begin to demand an accurate gauge, then the bottom rung will likely get accurate gauges. We're actually doing somewhat better than the Prius-Owning folk. They had to put up with a gasoline bladder for years, and were only granted a real gas "tank" for the 2010 model year. That wreaked a particular havoc upon their gas gauge accuracy. -Steve |
#23 |
One major complaint I have with ALL gas gauges is that when they read half a tank, how are we supposed to know if the tank is half empty or half full?
#24 |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
My first tank was not a good indication of the milage. The first bar dropped in the first 5 miles. I usually drive 250 miles after the first bar drops.
Making a decision without following it with an action is still a fantasy. |
#25 |
I'm not exactly a neophyte when it comes to fuel gauges. This one is duff: after nearly 3 years, this gauge is completely unreliable, sticking sometimes, working fine other times.
The gauge I had on a Brit car was sensitive enough that it would jiggle just below full after 50 miles, and jump off empty when the last half-gallon sloshed across the bottom of the tank; amazingly, I got used to that kind of accuracy. That was old technology; now it has been replaced by this crap... |
#26 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
+1 S.B.27 . The '07 PRIUS we had drove me nuts during fill ups . Took forever to fill during winter and summer since the bladder would get stiff ( shrinkage
) from the cold and the summer fills were difficult from the fumes kept in the bladder making the nozzle click off constantly . Also , on a few occasions the gas came gushing / spurting out thanks to unpredictable bladder . So , accurate fills were nearly impossible .
#27 |
![]() ![]() ![]() Drives: 2010 Yaris "5-door" Join Date: Mar 2009
My '87 Corolla gas gauge is pretty consistent - wonder what's up with the newer ones?
#28 |
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
I' don't dislike how it looks but how it works is other thing, you have to get use to it the first bar normally I get 60 to 70 miles to the second one 110 or a little bit more, each bar will disappear almost at the same speed until half tank, then each bar goes faster.
I use to have a Scion Tc and the same thing after half tank the needle will drop faster, maybe Toyota’s have that tendency, Previous to my Yaris I use to drive a 350Z and I remember the gas gage will normally go down accordingly of course it wasn’t perfect like it should be. The best way to be safe is resetting your Trip |
#29 | |
![]() ![]() ![]() ![]() Drives: 09 3dr LB MT Join Date: Aug 2009
I dislike the "bar" gas gauge. I would rather the old style needle gauge for the fuel. I don't watch my gas gauge the entire time I'm driving, since I'm trying to watch the road. At least then I'd know approximately where I was at. This one, I never see exactly when my gauge starts blinking. Whereas with the needle, I'd have a better idea of where it's at.
2009 3dr LB MT Meteorite Metalic. Car bought 8/7/09. Now over 89k miles of trouble free driving, other than user error!!
#30 | |
#31 |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
I will say this again
the gauge is damn accurate. but only Once it starts to move. at 4 bars you have exactly 1/2 tank left, and have already driven 1/2 the distance the full tank will give you at whatever average mileage you are doing. at 1 bar blink you have exactly 1.6 gallons left. compared with scangauge, the gauge is very accurate but only when it starts to move. the first bar takes a while to move due to float drowning |
#32 |
Half a Bubble Off Plumb
Plus, tank topping provides a variable amount of gas above the full point on the gauge.
#33 | |
-Steve |
#34 | |
-Steve |
#35 | |
-Steve |
#36 |
don't top off our cars anymore . Thanks to damage it can cause to the evaporator system . Here's a reason not to , www.mpt.org/motorweek/goss/2930.shtml .
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| gas gauge | cali yaris | Performance Modifications | 19 | 01-16-2009 08:41 PM |
| gas gauge issue | Bretsuaz | General Yaris / Vitz Discussion | 2 | 06-14-2007 11:00 PM |
| gas gauge and wiper jet spray | Adriaan | DIY / Maintenance / Service | 4 | 06-03-2007 02:13 AM |
| Free gas for any vehicle. | ketel0ne | General Yaris / Vitz Discussion | 4 | 09-19-2006 08:07 AM |
