Mr. Clean
Does the question pertain to a Yaris or an Echo?
It's been a while since I did mine, but I'm pretty sure there was a bracket that holds the shifter cables away from the header anyway. As long as they're not touching the header it will be fine. *Edit* I just looked at it and the shifter cables are about 8" away from the header. The 02 sensor wire is close, but it's shielded, has a brace holding it away from the header, and it was always there anyway. Last edited by TOUGEghost; 04-16-2010 at 01:07 AM. |
| TRD SSK & Shift Cable Bushings Issue/Question | minnyar | Performance Modifications | 5 | 04-14-2010 10:50 PM |
| Bronzoil Cable Bushings for the Yaris/Echo now available! | TWM Performance | TWM Performance | 58 | 03-31-2010 10:19 AM |
| NST shifter cable bushing users: Lube up! | schleppy | Performance Modifications | 11 | 07-05-2009 08:47 PM |
| Stock Shifter Shafts | TWEAKED_ICE | Performance Modifications | 8 | 06-02-2009 07:20 PM |
| NEW NST SS Shifter Bushing (AE86) | NonStopTuning | NonStopTuning | 3 | 10-01-2007 03:12 PM |
