Old 07-02-2009, 06:09 PM   #1
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
NST shifter cable bushing users: Lube up!
I recently installed some NST shifter cable bushings and I very much like them. I did notice that the shifter felt a bit "gritty" when rowing it around after installed the bushings. My car only has 5000 miles on it, so I figured the grit must be from the shiny NST bushings rubbing against the grit in the bushing carrier.
After spraying some Dupont teflon lube onto and around both bushings I was rewarded with a very nice, smooth shifter action.
So, go out there and lube those shifter cable bushings (if you haven't already)!
Old 07-03-2009, 05:59 PM   #2
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
I've been saying the same...
Some wd40 brought new life to my SSK / cable bushings combo
Old 07-03-2009, 07:00 PM   #3
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
I'll have to keep this in mind when i get the cable bushings...
Old 07-03-2009, 09:44 PM   #4
schleppy
I love momentum.
schleppy's Avatar
Keep in mind that WD40 isn't a true lubricant, it's a water displacer (hence the "wd"). I would put a longer lasting lube in there.
Old 07-03-2009, 09:47 PM   #5
jkuchta
Drives: 2007 Yaris hatch (red)
I use a little bit of Tri-Flow. It's pretty Bitchin' stuff that has one of those straw applicators that makes getting the stuff on the the bushings a piece of cake.
jkuchta is offline   Reply With Quote
Old 07-04-2009, 08:43 AM   #6
DerFlosser
DerFlosser's Avatar
WD-40 is a lubricant...it doesn't just displace water. The problem that I have with WD-40 is that it tends to attract dust and dirt. A needle applied teflon lube is a better choice.
DerFlosser is offline   Reply With Quote
Old 07-04-2009, 09:09 AM   #7
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I dont have the NST bushing set, but I shot some white lithuim on every joint in my shift linkage when I was trying to kill the squeak, and since then it shift sooooo much smoother with the engine bay NST SSK
Old 07-04-2009, 07:35 PM   #8
schleppy
I love momentum.
schleppy's Avatar
It is, but it's not very long lasting at all. And as you mentioned it attracts a lot of crap.
Old 07-05-2009, 10:15 AM   #9
DerFlosser
DerFlosser's Avatar
True...it doesn't last very long at all.
Old 07-05-2009, 10:46 AM   #10
AlexNet0
AlexNet0's Avatar
Schleppy you coming to the Natick, MA meet? we need more people.
</threadjack>
Old 07-05-2009, 03:36 PM   #11
severous01
moly-lube or graphite. any oil will attract dirt and cause u serious problems in the future. plus cleaning them is a pain when you grease or oil them up.
NST SSK-2 & Cable bushing kit & Cage bushing kit evan Items for Sale by private party 11 02-13-2009 11:04 AM
FS: NST quick shifter & tach mrbond Items for Sale by private party 19 01-16-2009 12:22 AM
NST short shifter mrbond Items for Sale by private party 5 01-07-2009 06:15 PM
NST Shifter Bushing Kit ruimond Performance Modifications 5 12-06-2008 12:48 AM
NEW NST SS Shifter Bushing (AE86) NonStopTuning NonStopTuning 3 10-01-2007 03:12 PM
