I love momentum.
NST shifter cable bushing users: Lube up!
I recently installed some NST shifter cable bushings and I very much like them. I did notice that the shifter felt a bit "gritty" when rowing it around after installed the bushings. My car only has 5000 miles on it, so I figured the grit must be from the shiny NST bushings rubbing against the grit in the bushing carrier.
After spraying some Dupont teflon lube onto and around both bushings I was rewarded with a very nice, smooth shifter action. So, go out there and lube those shifter cable bushings (if you haven't already)! |
Who said Yaris was slow?
I've been saying the same...
Some wd40 brought new life to my SSK / cable bushings combo |
Heart Up! Vitz
Drives: トヨタ Vitz Join Date: Jun 2007
I'll have to keep this in mind when i get the cable bushings...
I love momentum.
I use a little bit of Tri-Flow. It's pretty Bitchin' stuff that has one of those straw applicators that makes getting the stuff on the the bushings a piece of cake.
![]() ![]() ![]() Drives: Yaris Join Date: Apr 2009
WD-40 is a lubricant...it doesn't just displace water. The problem that I have with WD-40 is that it tends to attract dust and dirt. A needle applied teflon lube is a better choice.
I dont have the NST bushing set, but I shot some white lithuim on every joint in my shift linkage when I was trying to kill the squeak, and since then it shift sooooo much smoother with the engine bay NST SSK
I love momentum.
It is, but it's not very long lasting at all. And as you mentioned it attracts a lot of crap.
Schleppy you coming to the Natick, MA meet? we need more people.
</threadjack> |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
moly-lube or graphite. any oil will attract dirt and cause u serious problems in the future. plus cleaning them is a pain when you grease or oil them up.
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
I've got the bushing set and didn't lube it up. However, mine feels fine.
Subcompact Culture: The Small car blog |
| NST SSK-2 & Cable bushing kit & Cage bushing kit | evan | Items for Sale by private party | 11 | 02-13-2009 11:04 AM |
| FS: NST quick shifter & tach | mrbond | Items for Sale by private party | 19 | 01-16-2009 12:22 AM |
| NST short shifter | mrbond | Items for Sale by private party | 5 | 01-07-2009 06:15 PM |
| NST Shifter Bushing Kit | ruimond | Performance Modifications | 5 | 12-06-2008 12:48 AM |
| NEW NST SS Shifter Bushing (AE86) | NonStopTuning | NonStopTuning | 3 | 10-01-2007 03:12 PM |
