Old 04-16-2010, 09:01 AM   #1
severous01
why not do a spacer/adapter? if you re-drill the holes then the wheel will wobble. i had a friend in jersey put BMW 7 whels on his camaro...they were off just a bit so he widened 2 holes...he ended up snappin lugs.
if it doesnt fit right...something's wrong. and if it's wrong, then it wont work right...any way, do what you will. there's worse things on the road than someone trying to rig up some wheels.
Old 04-16-2010, 11:11 AM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
In all likelihood, you won't have room for adaptors. Filling existing holes is relatively easy and safe, and can be virtually invisible. Redrilling can be completed with absolute precision by the right shop. It wasn't long ago, that vendors routinely stocked blanks and only drilled wheels to meet specific application requirements.
Old 04-16-2010, 12:31 PM   #3
sasquatch
Drives: 04.:R32, 87 Scirocco, 07 yaris
well i do have a set of HR adapters sitting in my garage. the problem i'm running into is that where the existing studs come though i don't have/cant find a lug nut small enough to fit in the hole on the adapter. and the way that the 4x100 and 5x130 bolt pattern overlap there is hardly any room to open up the hole.
also kinda leaning against filling and re-drilling because of the way the wheels are drilled, i don't want them to look like shit.
wheels in question, so you can see what i'm talking about.
sasquatch is offline   Reply With Quote
Old 04-16-2010, 01:27 PM   #4
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Don't be stupid , just go and get some knock off wheels that fit and put a porsche sticker on them
Done
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 12:29 PM
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
DIY aftermarket steering, hub, quick release install AlainMikli DIY / Maintenance / Service 17 07-20-2009 06:01 PM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 03:32 AM
