shifter cable interference?
this was mentioned on echodrivers.com to me this morning and i havent looked in my engine bay yet to check, but how close do the shifter cables come to the header?
i installed a dc on the weekend and someone mentioned i should move/ziptie them out away from the header as they may be affected by the additional head of an unsheilded header i don't recall seeing the cables near the header, but could anyone confirm/deny their location and whether an unsheilded header would affect them on a yaris (vs an echo)
I don't remember them being particularly close to the header. I can't be of much help though, unless JR brings his yaris to work.
![]() ![]() Drives: 2007 Yaris Sedan (5pd) Join Date: Mar 2010
Having spent enought time ripping the skin off my arms yesterday I would say everything is close in the engine bay of a Yaris. That being said there is enough clearance that there shoudln't be any issues.
Mr. Clean
Does the question pertain to a Yaris or an Echo?
It's been a while since I did mine, but I'm pretty sure there was a bracket that holds the shifter cables away from the header anyway. As long as they're not touching the header it will be fine. *Edit* I just looked at it and the shifter cables are about 8" away from the header. The 02 sensor wire is close, but it's shielded, has a brace holding it away from the header, and it was always there anyway. Last edited by TOUGEghost; 04-16-2010 at 01:07 AM. |
#5 | |
i knew the o2 sensor wire was close, but it has that hanger.....i never noticed the shifter cables....but it came up on echodrivers.com that they MAY be close, so i asked here
| TRD SSK & Shift Cable Bushings Issue/Question | minnyar | Performance Modifications | 5 | 04-14-2010 10:50 PM |
| Bronzoil Cable Bushings for the Yaris/Echo now available! | TWM Performance | TWM Performance | 58 | 03-31-2010 10:19 AM |
| NST shifter cable bushing users: Lube up! | schleppy | Performance Modifications | 11 | 07-05-2009 08:47 PM |
| Stock Shifter Shafts | TWEAKED_ICE | Performance Modifications | 8 | 06-02-2009 07:20 PM |
| NEW NST SS Shifter Bushing (AE86) | NonStopTuning | NonStopTuning | 3 | 10-01-2007 03:12 PM |
