Old 04-19-2010, 02:58 PM   #1
Yariz
Drives: Yaris 3dr Hatchback
Where did you get spacer? I haven't seen a need for it yet. Do you have to change anything other than the injectors? Rail? Also, did you see an improvement?
Yariz is offline
Old 04-19-2010, 03:08 PM   #2
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
It came from another YW member who had it custom made. The injectors were added as a result of a CEL which was a lean code, he said after he installed the injectors the code went away.
I installed both TB spacer and injectors at the same time so I can confirm nor deny if there was ever such a condition or if larger injectors solve it.
You don't have to change the rail, stock one works fine. Might want to pick up new injector seals depending on the condition of the ones that are on there currently. Less than $10 for all four, so it's worth it to be safe.
No dyno so no real numbers. Since I installed both a TB spacer and the injectors I can't honestly say which was responsible but it does feel like it pulls harder at WOT.
Gas mileage has not decreased, however at cold start you can smell the difference because of how rich it'll run when warming up.
Gideon is offline
Old 04-19-2010, 05:33 PM   #3
cruz-gsr
cruz-gsr's Avatar
Drives: 08 Yaris Lift Back
i had the spacers made. its a 1nz on one side and 1zz on the other side. i will have another group buy soon.
cruz-gsr is offline
Old 04-19-2010, 05:38 PM   #4
Yariz
Why do I need that? My TB is working fine as is...
Yariz is offline
1zz injectors suit the S/C just fine LtNoogie Forced Induction Forum 51 04-30-2016 10:11 AM
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
1ZZ TB and AM Intake gwasabi Performance Modifications 5 04-06-2009 07:36 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
