#19 |
No. I installed an aftermarket 07-08 kit on my 09.
I purchased the 09 OEM fog light trim pieces from my local dealer and the OEM fuse panel relay from an Ebay vendor. By purchasing the relay I was able to wire it using the factory wires that go from the under hood fuse panel, through the under dash fuse panel, to the headlight stalk connector (this is the same for 07-09). I didn't like the quality of the switch that came with my kit and didn't want to spend the money for a headlight stalk with the fog switch, so I used a different toggle switch. |
#20 |
~ ambient one ~
Drives: 2009 Bayou Yaris Liftback Join Date: Jan 2007
Why do you guys always swear by Sparks ... I get parts cheaper at PartzNet.com (Conicelli Toyota), lol. People alwyas forget about them.
But to answer the Q of cheaper than $18 .. no I havent found them cheaper.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine ambientlifestyle.com------------ambientlifestyle.ning.com ![]() Micro Image Store - Network - Online microimageonline.com------------microimage.ning.com |
#21 |
One thing that I forgot to mention, is that my 09 came with the FOG fuse already installed. I purchased a variety pack of the microfuses, and then when I got under the dash to install the fuse, I realized that the FOG spot was already populated.
#22 |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Didn't know we had to install a fuse to get the fogs working. In my '07 all I did was connect the fogs to the box in the engine bay, plug the relay in inside below and to the left of the steering wheel and then install the new stalk.
#23 |
In that case, it sounds like that fuse is already there regardless of the year.
#24 | |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
#25 | |
I bought my relay from this ebay seller: http://cgi.ebay.com/ebaymotors/Toyot...lenotsupported |
#26 |
Sorry to post here but does any one have photos of the Fog Light Combo
Stalk , Before and after it was instaled , Please |
#27 |
![]() ![]() ![]() Drives: 2007 MX5 Join Date: Feb 2009
If I wanted to order just the Driver-side shroud....Would it be the RH or LH?
#28 |
#29 |
I know it = leftside but if you look at the diagram at TRD Sparks it shows the driver side listed with the RH.
#30 | |
Left side = #81482-52260 Right side = #81481-52330 Left side is certainly the driver's side and the right one is certaintly the passenger side. I verified this by holding it up to the car. Sparks' info must be wrong. |
#31 |
I have a set of 09-10 Hatch fogs and shrouds
100% plug and play and 100% complete $99.00US shipped i also have 1 set for the 06-08 Hatch and 1 set for the Sedan PM or email me for photo's . |
#32 |
Thank you all for your help. I only want the drivers side shroud to allow air into the fender area for my intake....Yes, it is for an '09 LB
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| Fog lights and shift knobs | flip_yaris | Cosmetic Modifications (Exterior/Interior) | 4 | 09-26-2006 10:48 AM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
| Fog lights for S sedans (US version) | paeko73 | General Yaris / Vitz Discussion | 11 | 07-02-2006 11:38 PM |
