Just a Herbicidal maniac.
Drives: 2008 Yaris S Sedan Flint Mica Join Date: Oct 2008
Not to take this thread off topic, honestly, I haven't decided yet...still researching. Since I'm keeping the stock head unit, I want to find a good match without doing all the electronic upgrades that Derick has so very nicely diagrammed in earlier posts.
So a question here that I either missed the answer to or haven't seen it - for the stock HU, should I go with speakers that are 2 or 4 ohms? At this time I am not planning on installing any kind of amp. Yes, I know I won't enjoy the full capabilities of new speakers without an amp, but I've got to keep an eye on the $$$'s. Perhaps I can add a small amp later. Thanks!
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace. |
#2 | |
Front speakers: Pioneer 6.5 ($40) LINK Rear speakers: any 6x9 (>$40) LINK 2 cts I hope it helps I really don't know about the 2 or 4 ohms you could still add an amp or a small amplified sub later, this would be a good improvement.
. CLA 250, 4MATIC |
#3 | |
Audio Junky
I've ran 4ohm & 8ohm speakers before.... you won't here an audible difference between them... its all the other specs that will make an audible difference. |
#4 | |
Lookin' good Derick! You're gonna turn into a walking zombie with all those late nights! I hear you about the family, especially with a youngster demanding your attention. So...when are you to to "mod" the play structure? Stereo? Fridge? Ceiling fan? Lounge?
I just met my worst night mare!!!........FRONT RIGHT DOOR TRIM PANEL!!! I can't believe it, it was so hard... I know the extra layers of CCF and MLV was too much and I knew I was going to trim them to make it fit; I put on and off that panel maybe a couple dozen times, maybe more!!!, I spent all my hour of lunch trying and trying... at the end I was successful. Also had to take away the little foam on the upper part, and cut all the way down the big one. Looks like there are main points in the panel that go agains the inner door and felt like little bumps deflecting the panel making it impossible to put back in place. I hope this helps me plan the drives side door better. I'm exhausted ![]() I was so lucky my boss came back from vacations and he brought 2 pizzas for us! .
. CLA 250, 4MATIC |
I forgot to mention, that the THUMP coming from the door when I slam it... it's so GOOD, it's PRICELESS ![]() .
. CLA 250, 4MATIC |
#7 | |
Audio Junky
the 2ohm load on a deck will cause it to run very hot, and possibly blow fuses. There are a lot of electronics that give off heat in a deck even before you consider the amplifier. I have a deck that doesn't even have an internal amp, it only has a 2amp fuse, and the front of it gets warm.... now compare that to a deck which will have around a 10amp fuse. Usually when people talk about running a 2ohm speaker, it's because they want to get every last watt of power out of their external amplifiers. |
#8 | |
1. Kicker KS60.2: 1 @ $109.99 (doors) 2. Alpine SPR-69C: 1 @ $99.99 (rear deck) I've got my car 1/2 torn apart and would like to ONLY get into the doors and rear deck once! Better to beg for forgiveness than ask for permission!
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
