Compulsive Washer
Distribution block?
Hey YW, it's me again.
I'll most likely be running amp wires thru my Yaris sometime this week. I'm still not 100% sure which amps I'll be running, but it'll most likely be a TMA T2-500.1 to power my sub, and and a Powerbass ASA 600.4 for my speakers. I have a couple of questions. So, from what I've read, I think what I should be doing here is routing some 0/1ga from the battery into the car, and then split it into two 4ga wires, each running to each amp. 4ga will be used for grounding each one as well. First, my door speakers are 50W RMS, feeding them 100RMS won't kill them unless I get stupid and overload them right? Second, would I be better off with running 0/1ga or would 2ga be enough? Third, is it really necessary to use a distribution block? or can I just run a fuse rated half as big as the one on the 0/1ga coming from the battery on the 4ga wire going to each amp? Thanks in advance |
| DIY: Engine Grille Block | BailOut | DIY / Maintenance / Service | 39 | 11-11-2017 09:33 PM |
| engine block heater | linny | DIY / Maintenance / Service | 6 | 01-19-2012 11:22 AM |
| Block guard | Paris vvt-i | Performance Modifications | 13 | 12-19-2009 12:55 AM |
| Where to find block heater cable that was factory installed? | D6U4 | General Yaris / Vitz Discussion | 5 | 12-16-2008 07:04 AM |
| Florida Grille Block? | drummerboy2004 | Fuel Economy Forum | 2 | 11-17-2008 02:00 PM |
