Old 04-27-2010, 11:51 AM   #1
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by Bluevitz-rs View Post
From there back, you don't need more fuses to each amp.
Wrong.... anytime you reduce the wire size you need a proper sized fuse.
Try to run a distroblock that has fused built in (for the power cable). Most people don't, tho if you had an EE, or safety inspector looking at your install, they'd be all over you if you don't fuse each reduction in wire size.
What you can do, is do 1/0awg and then just run a 80amp fuse (60 amp may work, may pop, and 100 would also work too) next to your battery. 4awg can safely transfer 125amps of current for about 15 feet I think, so as long as you go with a smaller fuse and not something like a 150/200/250 amp fuse you won't have to double fuse the power cable.
Old 04-27-2010, 12:15 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
That is the point that I was trying to make, just more direct...thanks talnlnky. KNUCONCEPTZ makes a great Distro block which is what I use as an example:
http://www.knukonceptz.com/productDe...?prodID=KNF-12
KonFUSED 2 Way Distribution System
[Knukonceptz Item #KNF-12]
NEW ITEM - The KonFUSED Distribution System is tailored by the installer to fit ANY installation requirement. With interchangeable Kompression Fittings anything is possible. The KNF-12 has one input port, which by changing the Kompression Fitting, can accept 4 Gauge or 1/0 Gauge Cable. The output side can be adjusted to accept 4 Gauge or 8 Gauge cables. Please see our reference chart link below to see what fittings are included with this model. Using the Mini-ANL Style Fuse, the KNF-12 can maintain loads up to 150A per circuit.
Included with the KNF-12 are 6 Kompression Fittings to allow the end user to customize the block to fit their application. Also included, your choice of two (2) Mini-ANL fuses! The KNF-12 is finished in black chrome and includes the smoke acrylic cover
KonFUSED System Introduction
Kompression Fitting Chart / Spec Sheet
Category: Distribution / Fuse Blocks
In Stock: No
Weight: 0.85
Price: $14.99
Like I said, this is what I use and it has proven to be a great purchase and for 15 bucks utilizing the ANL fuses I am not sure that it can be beat...
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 09:33 PM
engine block heater linny DIY / Maintenance / Service 6 01-19-2012 11:22 AM
Block guard Paris vvt-i Performance Modifications 13 12-19-2009 12:55 AM
Where to find block heater cable that was factory installed? D6U4 General Yaris / Vitz Discussion 5 12-16-2008 07:04 AM
Florida Grille Block? drummerboy2004 Fuel Economy Forum 2 11-17-2008 02:00 PM
