Old 04-28-2010, 01:34 AM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
looks good man...just make sure that you have the distro in an accessible place even if it is hidden...
Old 04-28-2010, 01:36 AM   #2
DFA
Compulsive Washer
DFA's Avatar
Drives: 08' AT Meteorite Metallic LB
Send a message via MSN to DFA
Yeah, I'll probably end up putting it under the center plastic thing where the cupholder and the ebrake are, there's apparently quite a bit of free space under there, and I'll just route the wires to and from it under the carpet.
DFA is offline   Reply With Quote
Old 04-28-2010, 01:48 AM   #3
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
How many outputs does your headunit have ? Does it have a Subwoofer, Rear and Front ? or Just a Rear and Front, If you only have two sets you will need Two Y Splitters on the RCA cable going to your 4 channel so you can run all four channels on the amp.
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 09:33 PM
engine block heater linny DIY / Maintenance / Service 6 01-19-2012 11:22 AM
Block guard Paris vvt-i Performance Modifications 13 12-19-2009 12:55 AM
Where to find block heater cable that was factory installed? D6U4 General Yaris / Vitz Discussion 5 12-16-2008 07:04 AM
Florida Grille Block? drummerboy2004 Fuel Economy Forum 2 11-17-2008 02:00 PM
