Old 04-30-2010, 02:26 PM   #1
DFA
Compulsive Washer
DFA's Avatar
Drives: 08' AT Meteorite Metallic LB
Send a message via MSN to DFA
If I go ahead and place it under the passenger seat, there would only be about a foot of 4ga running from the distro to the amp, but about 5 or 6 feet to the mono amp. If I have to make a compromise and get noise in either my door speakers or my sub, I'd get it on my sub, which cannot play high frequency noises I guess.
Still have no idea how I'm going to go with mounting it tho, since the area under the ebrake/shifter is a messy pile of bare metal everywhere.
DFA is offline   Reply With Quote
Old 04-30-2010, 06:01 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
You shouldn't get noise unless you forget to tighten the screws down on the d-block... or you use 10awg cable instead of 4awg.
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 09:33 PM
engine block heater linny DIY / Maintenance / Service 6 01-19-2012 11:22 AM
Block guard Paris vvt-i Performance Modifications 13 12-19-2009 12:55 AM
Where to find block heater cable that was factory installed? D6U4 General Yaris / Vitz Discussion 5 12-16-2008 07:04 AM
Florida Grille Block? drummerboy2004 Fuel Economy Forum 2 11-17-2008 02:00 PM
