Old 04-30-2010, 09:34 PM   #1
Did you see the threads about the TSB on the HVAC smell? Yours probably falls into the list of affected serial numbers.
The smell is supposedly due to a material issue with the evaporator.
If it isn't the TSB issue, the other common cause is the airbox being backed up with condensate. If you don't have a cabin air filter installed then "stuff" can get sucked in from outside when you are running the AC with outside air. If that "stuff" gets into the airbox it will plug up the condensate drain.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 04:31 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
