Old 05-01-2010, 01:07 AM   #1
DFA
Compulsive Washer
DFA's Avatar
Drives: 08' AT Meteorite Metallic LB
Send a message via MSN to DFA
well, awesome.
I just mounted the distro block right where I wanted to, I noticed 2 bolts about an inch apart next to the ebrake, so, I screwed two ... " flat metal rectangles with two screw holes" (my english falls short sometimes, bear with me :P) to the underside of the plywood base I made for the distro block, and put the bolts through the other holes, let's just say it won't be moving anywhere anytime soon =)
Now, for some reason, I noticed my HU isn't sending a 12V signal thru the blue/white cable, I sent a remote turn on cable to the back of the car, checked with a DMM and there's continuity between the HU and the wire on my trunk, but then I turn on the HU and take a voltage reading between it and the chassis, I get really lame and inconsistent readings around 2-3V.
I don't have an amp hooked up to the remote turn on cable, does the HU somehow only send the signal when there's something hooked up?
DFA is offline   Reply With Quote
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 09:33 PM
engine block heater linny DIY / Maintenance / Service 6 01-19-2012 11:22 AM
Block guard Paris vvt-i Performance Modifications 13 12-19-2009 12:55 AM
Where to find block heater cable that was factory installed? D6U4 General Yaris / Vitz Discussion 5 12-16-2008 07:04 AM
Florida Grille Block? drummerboy2004 Fuel Economy Forum 2 11-17-2008 02:00 PM
