Old 05-06-2010, 03:07 PM   #1
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I can do it all myself, and budget will be a couple hundred ordering over the next few months. would like to run the 4 speakers to a small amp, as I am building a carpc as well and need the source input
Old 05-06-2010, 05:18 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
like I say in all threads like this... only replace your front speakers, and if you can fight the urge, don't connect your rear speakers. This will allow you to get speakers that cost twice as much, and should be of much greater quality. two speakers is all you need to get loud, in fact, 1 speaker is all you really need, but you need two for stereo effect. Furthermore, a 2 channel amp is cheaper than a 4 channel, and its nicer on your electrical system. A smaller amp will also mean you can get away with using smaller guage power wire which is cheaper too, and lighter, and easier to work with.
You get where I'm going with this... the benefits of running 2 speakers is almost exponential compared to 4 speakers... and i'm only talking about the cost so far. There is also sound quality improvements as well.
You can get a decent set of component speakers starting at around $100-120 if bought online ($200 in stores).
Since you like always loud metal.... i'm going to guess that you'd be a fan of shrill tweets like the metallic tweets found in MB Quart or Focal... JL also uses metallic tweets, tho they seem include a crossover that tames the tweet a lot more than the Quart & Focal crossovers do.
so... your homework... go listen to some speakers, listen to speakers which use a metallic looking tweet (will look like its made out of mylar or some other thin metal material, like the ballons) and then go listen to some other speakers that use a soft dome tweet, or silk tweet. See which speaker has the best sounding highs.
TAKE A CD OF YOURS WITH YOU... you have to compare using music you are familiar with other wise the comparison is pointless.
If you go to an Infinity dealer it'll be easy to compare, the Refrence line of speakers use a soft dome tweet, the Kappas use a mettalic tweet.... tho, Quart and Focal are probably the most notorious for having harsh/shrill tweets.
Old 05-09-2010, 01:25 AM   #3
H3LlIoN
Drives: '09 Yarrrr hatch
Head on up to your local Best Buy. You might find that Rockford Fosgate products are....extremely well priced right now through them.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Speakers for 2009 4DR LB AutoXBot In Car Entertainment + Electronics (audio / video / alarm) 5 05-02-2010 11:49 PM
went to a car audio shop...they suggest 8" speakers severous01 In Car Entertainment + Electronics (audio / video / alarm) 11 03-24-2010 09:15 PM
Which Speakers??? Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 23 12-08-2009 07:52 PM
Factory deck, new speakers sound no sound?? alan1828 DIY / Maintenance / Service 4 10-25-2009 03:36 PM
Fitting rear speakers in Toyota Yaris nish1979 In Car Entertainment + Electronics (audio / video / alarm) 4 03-22-2009 11:56 PM
