Old 05-06-2010, 06:23 PM   #1
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by Herbicidal View Post
Excellent write up! The pictures answered some questions I had about the wiring harness on the back of the stock HU.
With my car 1/2 torn apart, I'm still toying with getting a small amp to power my new speakers. Since the wires coming from the back of the stock HU are pretty thin, will running the same gauge wires to an amp help me all that much? Even if I upgrade the wires to a lower gauge (smaller the number the thicker wire right?) from the back of the HU to an amp, I'm still starting out with thinner wire. So, would it be best to run thicker wire from the amp to the speakers? I read somewhere else here on Yaris World that I may need a 'line out converter' and an 'amp wiring kit', anything else?
Hopefully it's OK to ask these questions in this thread. At this time I am not replacing the HU which I know would simplify everything.
Thanks!
The speaker wires coming from an amp into into the speaker don't have to be thick to be good. Those wires carry a high voltage, low amperage signal.
Amperage is what causes heat issues in car audio, not high voltage. you could run a sub with 2000watts of power and 22awg wire and be perfectly fine and not see a decrease in volume (due to loss of power).
the power & ground cables however are high amperage low voltage, so they produce heat, and have to be big, or else you'll run into diminishing returns & even safety issues due to loss of power in the form of heat in the wire (which can start car fires).
Old 05-07-2010, 01:11 AM   #2
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
I sure don't want a car fire! I've been looking at some of the amp wiring kits at Crutchfield and Sonic Electronix and they all seem to come with heavy gauge power and ground leads. Plus they include decent size gauge wire from the amp to the speakers.
Also, from what I gather is that a line output converter would simplify connecting my stock HU to the amp, correct? Like this example from Scosche.
Thanks for the help!
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 05-07-2010, 11:50 AM   #3
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Yes, a LOC would do it, if you choose Scosche go to Walmart only $17
Sqcomps recommended me [I do too.] these:
MTX-re-Q for subwoofer only, but if you in the future want to add an amp for your speakers go for:
MTX Re-Q5
I'm going towards changing to a HU...
CLA 250, 4MATIC
07 Sedan Factory Integrated Radio - SoCal Locals First Dibs eii Items for Sale by private party 6 11-30-2010 09:29 PM
Source of buzzing sound.. CB900F2 DIY / Maintenance / Service 1 05-20-2009 11:19 PM
Source for factory style spoiler?? imknotright DIY / Maintenance / Service 6 10-18-2006 02:47 PM
