Old 05-09-2010, 09:10 PM   #1
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
It will be very easy if:
You should FIRST, Spray a little PB, wait 30 minutes or so and then spray it again. Then use a 6-point socket to remove that bolt. It's hard, but it will come off much easier when you use that PB Catalyst. Trust me !
http://www.amazon.com/Blaster-Chemic.../dp/B0010E4FTW
The PB shoots like a water gun so don't fret when you see no red tube to spray the bolt using the can. It's REALLY good at taking bolts off. I couldn't remove my CAT bolts with an impact wrench 250 f/p and it was making the head of the bolts off-shape. Sprayed the PB and 30 minutes later, on the second impact like (Tack-Tack whirr), the bolt came spinning out like on steroids.
bobolinko is offline   Reply With Quote
Old 03-21-2011, 02:29 PM   #2
dyslexicanaboko
Drives: 2007 Toyota Yaris
I am looking for some advice on the exact same issue. I have worked on a number of cars, although not being a mechanic, still for the basic stuff it isn't rocket science.
However I was trying to change my belt and I ran into the same problem of having no room to work in and having the #$&*&!? A/C conduit in the way of the belt. So I made attempts with my socket wrench, it was a no go, I tried a box wrench and that is when I rounded the nut, a 14mm anything no longer works.
My question is, should I just stop trying, suck it up and go to a mechanic , or should I try:
Using the PB Lube (mentioned above). Then with a cresent wrench or other tool; hope to loosen the bolt?
The points on the bolt are rounded, but the flat portions are partially still intact.
dyslexicanaboko is offline   Reply With Quote
Old 03-25-2011, 10:30 AM   #3
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
pricey
You can get that a walmart a lot cheaper
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Belt Tensioner for the Yaris fmicle DIY / Maintenance / Service 25 11-26-2022 11:37 PM
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Seat belt buzzer is silenced billk General Yaris / Vitz Discussion 48 10-30-2013 09:58 AM
Drive belt question toyo DIY / Maintenance / Service 4 02-22-2010 07:42 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
