Old 02-19-2010, 01:01 PM   #1
toyo
Drives: toyota
Drive belt question
I read the article on the 400k mi yaris, said that it had the drive belt replaced.
what exactly is the drive belt? the one for the hydraulic steering? alternator? AC?
my car has a "squeaking" sound in the engine compartment, believe it's a belt that need replacement, wondering which one it is XD
1st gen FTW
toyo is offline   Reply With Quote
Old 02-19-2010, 01:49 PM   #2
127.0.0.1
that would be the accessory drive belt
Old 02-19-2010, 04:34 PM   #3
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
The Yaris does not have hydraulic steering, it is electric.
The AC and alternator all run on the accessory belt, or the serpentine belt. I had mine replaced at around 75000km but I find it needs to be tightened often, especially if you live where there are bumpy roads lol.
devinlamothe is offline   Reply With Quote
Old 02-19-2010, 06:55 PM   #4
markitect
Our accessory belt has no tensioner, so it may just be stretched out a little. You can loosen the alternator bolts, then use a crow bar(careful what you brace it on) to hold the alternator to increase the tension on the belt and re-tighten the bolts.
markitect is offline   Reply With Quote
Old 02-22-2010, 07:42 PM   #5
exit90a
Drives: 2007 Yaris
Page EM-8 covers the belt tension procedure...
http://www.etimago.com/yaris/repairm...Mechanical.pdf
exit90a is offline   Reply With Quote
Seat belt buzzer is silenced billk General Yaris / Vitz Discussion 48 10-30-2013 09:58 AM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
Question: alignment setting for a daily drive and track car? Trish Performance Modifications 4 06-15-2009 12:04 PM
Water pump belt and pulley - replaced at 36,000mi cleong DIY / Maintenance / Service 3 03-06-2009 12:12 AM
Best Grease to use on the belt? hasher22 DIY / Maintenance / Service 11 04-23-2007 02:20 AM
