My Little Blue Egg :)
Drives: '09 3 door Yaris Join Date: Dec 2008
Windshield washer fluid
Hello guys,
I was wondering If it would do any harm to use windshield washer fluid with de-icer right now. It is now warm out, and will remain hot for the summer. Is it fine to use the de icer windshield washer fluid? Thanks :) |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
Yes, it's designed for year round use.
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
It is fine as in it won't ruin your windshield, but it's not so good for you or your passengers if the fumes are inhaled via open windows or vents, or for your local environment if any of it is spilled or over-sprayed. There is some toxic stuff in that fluid.
I just make my own fluid with 2 tablespoons of vinegar in a gallon of water, and 1-2 drops of lavender oil. No detectable foul odor, food grade, fully biodegradable, a few pennies for each gallon and all throughout last winter I never had it freeze in the lines or on my windshield, even on snowy and windy days at high altitude (my engine grille block likely helped with that, so YMMV).
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. Last edited by BailOut; 05-12-2010 at 12:56 PM. |
it's isotopyl kind of alcohol in there. Anyhow, it smells the same.
#6 | |
On a trek to upgrade...
Drives: 2003 Echo Coupe Join Date: Mar 2010
| No Windshield Washer Fluid Light | captainm27 | General Yaris / Vitz Discussion | 20 | 12-18-2015 05:49 AM |
| Adjusting Windshield Washer Jets | N9QGS | DIY / Maintenance / Service | 7 | 06-08-2010 10:10 PM |
| Windshield Washer indicater always on | mlaverdiere | General Yaris / Vitz Discussion | 3 | 01-17-2010 02:43 PM |
| Windshield Washer Indicator | captainm27 | General Yaris / Vitz Discussion | 25 | 01-21-2009 07:26 PM |
| New TSB Bulletin For Windshield Washer Sprayer | Yaris | General Yaris / Vitz Discussion | 14 | 06-01-2007 01:47 PM |
