Old 05-13-2010, 08:04 AM   #10
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Originally Posted by rob323 View Post
I want a closer ratio gear set and shorter final drive because my drag strip can be up to 40 kms long and usually has lots of hills and corners.
As you described we call it hill climb sprint.
Can you tell us why you chose a C56 trans and not a C160 to swap into a C150?
Bluevitz-rs made a good thread that explains it all that it can be done. http://www.yarisworld.com/forums/showthread.php?t=26728
The C160 transmission is a closer ratio than the C56.
The purpose of this thread was in order to know if the C160 LSD fits the C150 that's all
C54 MANUAL TRANSAXLE service manual needed ricepower DIY / Maintenance / Service 1 08-29-2007 07:24 AM
